dual bulb led? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2012, 05:41 PM   #1 (permalink)
Member # 63299
dual bulb led?
Looking for some small led lights that can be used as both running and turn signals on front of my buggy. Need a complete assembly that has bulbs for.both in amber
74 FJ40- one tons, 42's
Spacecwboy is offline   Reply With Quote
Old 05-13-2012, 07:06 AM   #2 (permalink)
Bobbing for Fries
billy bones's Avatar
Member # 190574
Search around for street rod lights. There are many shapes and sizes available. One example HERE
Good luck
If everyone is thinking alike, then somebody isn't thinking.
billy bones is offline   Reply With Quote
Old 05-13-2012, 03:53 PM   #3 (permalink)
Member # 101802
http://www.superbrightleds.com/cgi-b...sp=%2F1157.htm
Not connected to them in any way...just passing a link...
yyc_ranger_4x4 is offline   Reply With Quote
Old 05-13-2012, 07:19 PM   #4 (permalink)
Member # 63299
i tried there but cant seem to find what i am looking for. i dont have a control module to make the single bulb switch between running and turn signal so i need something that 2 lights in it that do 2 functions or some sort of electronics that do that for me but i dont know what it would be called so i dont know what to search for.
Old 05-14-2012, 01:22 PM   #5 (permalink)
Member # 57353
These won't work?
Also, if that doesn't suit your fancy, you could use a trailer light converter like so.
TheAlmightySam is offline   Reply With Quote
Old 05-14-2012, 03:02 PM   #6 (permalink)
Member # 63299
im looking for something pretty small. they are going in place of the marker lights on the front fenders of my fj40, they are 1x3 or so. i found a set of marker lights in my shop but they are single function lights. i may just have to get creative
Old 05-14-2012, 03:27 PM   #7 (permalink)
Member # 57353
In that case, use the trailer light converter I posted above. That'll take your three wires (running, left turn, right turn) and make them work with a single function light. Your marker lights will work just like the tail lamps on an older American car - on solid with the marker lights, blinking with the turns.
Old 05-14-2012, 07:25 PM   #8 (permalink)
supersize75k5's Avatar
Member # 29341
http://www.amazon.com/Rear-Stop-Turn.../dp/B0010B8EL0
http://www.amazon.com/Amber-Motorcyc...xgy_auto_img_b
I run something like this,
supersize75k5 is offline   Reply With Quote
Old 05-14-2012, 08:20 PM   #9 (permalink)
Member # 63299
i have 2 of them, one for the front and one for the back but never could get them to work right so I got aggravated and pulled them out. Im not sure why they wont work, not sure if it is an issue with LED lights and not enough draw or what the problem is. im also now looking for diodes to put on the turn signals so they dont back-feed. is there a particular amp or something that I should look for?
Old 05-15-2012, 05:12 AM   #10 (permalink)
Member # 9679
I don't think that's right. Those converters are for a system with amber turn/ dual element red tail/brake to a dual element tail/brake/turn. They also prevent backfeed from lighting your entire system when you step on the brake or turn.
77fixer is offline   Reply With Quote
Old 05-15-2012, 08:24 AM   #11 (permalink)
Member # 57353
Might be a resistance problem with the LEDs - that seems to screw up a lot of stuff. If that's the case, you can find a resistor of the correct ohms to wire inline (I think SuperBrightLEDs.com sells them) or just find a different solution.
You're correct that converters are intended for a dual-filament system, but I've never actually seen one that bothers with the low-intensity filament (parking lights). Since that's on a separate wire on every vehicle I know of, that's it's own thing. Look at the wire inputs on the one I posted. It takes the three bright signals (left turn, right turn, brake) and turns them into two bright signals. My suggestion was to hijack the brake functionality and make it into the parking lamp function - the light will be bright when the parking lamps are on, and blink off to signal.
If the LEDs don't have enough resistance to make it function, however, that's another story entirely.
Old 05-16-2012, 02:05 PM   #12 (permalink)
Member # 86724
http://www.superbrightleds.com/cgi-b...rake-turn.html
use any marker light housing that fits, just replace the bulb with a drop in LED.
ko derf
87manche is offline   Reply With Quote
Old 05-16-2012, 06:48 PM   #13 (permalink)
Member # 63299
im looking for something this size but so far have struck out..
Old 05-16-2012, 07:27 PM   #14 (permalink)
Member # 63299
found them finally on ebay on accident.
Old 05-20-2012, 03:08 AM   #15 (permalink)
Member # 210384
This might be handy..
/forum/electrical-wiring/1064350-12volt-circuits-tricks.html
Figjamjake is offline   Reply With Quote
