Member # 141521
Weeding a 4.0 HO harness
Pulled one out of a cherokee today. I see the main engine harness unplugs from the ECM seperately, but what about the other harness that plugs into it? This one has the transmission controls in it and the plug for the coil packs, but is there anything else in it that's critical to the engine and trans running?
2005 Rubicon Unlimited |
#2 (permalink) | |
PBB Official WTPOS
Member # 170546
Member # 73413
Do yourself a huge favor. Do not remove or mess with the harness until you have the engine in the vehicle and fully functional. At that point remove things that you will not need.
*blank*
Member # 109953
when i swapped in my TJ 2.5 (yeah i know...) all i used was the engine harness and the harness that the computer plugs into that hangs on the back of the firewall. It has 3 big plugs on the drivers side that plug into the interior harness. Thats where i cut into it to grab the ignition stuff.
Member # 138167
I would recommend subscribing to AllData.com for the specific year/model of the doner vehicle. They have in my experience the most accurate and detailed wiring diagrams that are year specific. Last time I did one, it was like $30 for a year per vehicle. Well worth the money if you are going to go through a harness IMO.
AKA - Dusty Booger Jeepspeed 1749 (1719 2008 Baja 1K) ![]() www.dirt-fab.com e-mail: info@dirt-fab.com Phone: 510-502-8508 |
What year are those diagrams from? I have a couple harnesses from HO motors and they are all a bit different. OBD1 or OBD2?
Andy~ RCrocs/Line Mt. - Route 63 Motorsports #736 Ultra4 #4343 Co-driver - Molten Motorsports |
#9 (permalink) | |
Member # 142612
Ask yourself again: what year are those diagrams? is it OBD1 or 2?...
I speak, eat, drink and breathe JEEP. “Great people talk about ideas, average people talk about things, small people talk about other people.” |
Member # 142733
um... those diagrams are for wrangler W/H layout... not XJ. XJ's don't have three plugs like that.
On XJ (4.0L w/AW4) OBD1 systems the main engine room harness has one large bulkhead connector on the driver side at the firewall, a large connector for the ECU, a grom that goes through to the TCU, two or three WtoW connections with the engine/tranny harness, an RB and a WtoW connection with the grille harness. On the other side of the bulkhead connection wires run to the IP and back to th back of the vehicle. My TJ actually has all XJ wiring, engine and the AW4. I'm also researching how make a stand alone harness for just the engine/tranny... and also how to swap it over to aftermarket gauges so that I can get rid of the xj cluster that is zip tied to the dash bar of the roll cage.
Chuck Norris gave Paul Newman the recipe. |
#11 (permalink) | |
Member # 86724
ad since the OP mentioned that it has coil packs it has to be an 00 or 01 donor vehicle. and if you've used the OBD1 harness in your buggy the gauges are simple. OBD1 didn't have a can bus or anything that related to the ECM with the guages. So just swap out the gauge senders with aftermarket ones and hook up your aftermarket gauges. The ECM and the gauges were completely different senders.
ko derf |
#12 (permalink) | |
Member # 142612
YOUR XJ harness does not have three plugs like that, because you are talking about the Chrysler SBECII (single board engine controller) MPI system, that was used from 1991 to 1996 on the l4.0 engine with a single 60 way connector.
#13 (permalink) | |
Member # 53528
#14 (permalink) | |
WHEEEEEEEEEE!
I weeded out a 95 Cherokee harness to just the essential motor sensors and 2 relays. There is a lot of junk you do not need in the fuse box. Like someone else said, get it running FIRST, then weed it out. Not having it start after you mess with it, and not knowing if it ever worked to begin with, is beyond frustrating.
#15 (permalink) |
Member # 142612
I prefer the Renix system, based on Formula 1 technology of the first 80s, it is pre/OBD and it doesn't have a limp home mode. It was designed to perfectly work in open loop mode without an oxygen sensor (my '88 xj does not have one from the factory, neither a catalytic converter) and it has a self diagnostic feature that compares the measured values to preset limits: If the value sensed does not lie in these limits it is treated as defective and the ECU auto-generates known average values to determine injection pulse width and ignition timing.
The engine will still be fully operative with a malfunctioning MAP, MAT, TPS, Knock, CTS, OS and battery. Only CPS and camshaft positioner are essential to keep the engine running, maybe rough at idle, but fully operative at WOT.
#16 (permalink) | |
Member # 86724
I loves the RENIX. You just have to have an understanding of how it works and you can make it run with nothing more than a multimeter and some bubblegum for the most part.
ko derf |
#17 (permalink) |
Member # 142612
You agree with an asshole with no awesome? Wierd.
Three spare parts in the glovebox and you're good to go for 30 years on a Renix. A CPS, a fuel pump and a set of injector o-rings.
I speak, eat, drink and breathe JEEP. “Great people talk about ideas, average people talk about things, small people talk about other people.” Last edited by fantic238; 05-30-2012 at 12:58 AM. |
#18 (permalink) | |
Member # 86724
I know people hate the Renix, I am a proponent. Just because the ECU doesn't self diagnose with nifty number codes does not make it harder to work on. probably easier actually, because you actually have to understand it and troubleshoot it properly instead of reading codes.
ko derf |
