Wiring transmission sensor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2012, 08:15 PM   #1 (permalink)
Weasel's Avatar
Member # 5639
I have a Stewart Warner transmission temp sensor I'm trying to wire. The sensor is in a AN T-fitting that is inline of the rubber transmission lines, ie it's not grounded against anything.
I had the sensor originally wired with a single wire that ran to the gauge but the needle won't move off the lowest setting, just under 140.
So I figured I need a ground wire so I ran a ground but if I attach it to the sensor stud the needle pegs out a the max of 320.
How do I wire this stupid thing? I have been searching google without much luck.
I tired clamping the ground to the side of the sensor with a vise grips and got the fluid up to ~145 and the needle didn't move.
Just Add Lightness
I'd rather be simple-and-wrong than complicated-and-wrong.
Weasel is offline   Reply With Quote
Old 05-18-2012, 06:53 AM   #2 (permalink)
Member # 207169
The top post is for the the trans gauge and the the body has to be ground without touching the top post...Try another gauge if you can because you might have burned out the gauge by ground out the sensor wire...
TorqueRanger is offline   Reply With Quote
Old 05-19-2012, 03:04 PM   #3 (permalink)
pepe's Avatar
Member # 17870
Is this it?
You are correct in that the body needs to be grounded. It sounds like your gauge is working. I welded a stud to the "T" on mine and connected the ground there. You could always test it in a can of boiling water, boiling would be 212 deg F.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself!
pepe is offline   Reply With Quote
Old 05-19-2012, 03:23 PM   #4 (permalink)
Member # 56430
You have a ground problem. This is similar to how both mine are done, with a sender in the rubber hose. The sender screws into a fitting. Take your solder gun, and wrap bare wire around the fitting (not the sender), then solder the wire to the fitting. That becomes your ground strap.
And even though the engine is up to operating temps, the trans will take a significantly longer time to come up to temp, and that's typically under load, not idling in your driveway.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12
Member Eldorado Dust Devils, a PNW4WDA member club
Treeclimber is offline   Reply With Quote
Old 05-23-2012, 10:26 PM   #5 (permalink)
Weasel's Avatar
Member # 5639
cool, thanks that what I was thinking. And yeah the trans takes along time to warm up sitting in the driveway, lol.
Just Add Lightness
