Member # 108492
Removing wires from back of fuse panel?
Is there a special tool to remove wires from the back of a fuse panel?
I have an aftermarket wiring harness (previous owner purchase) that has WAY too many circuits for this particular vehicle and I would like to remove the excess wire from the fuse panel. Granted I could just snip the wires, but I would rather pull them out. I pulled one out by just pulling REALLY hard, but I'm pretty sure that isn't the right way to remove them. . .I tried getting some small needle nose pliers in there to squeeze the terminal legs (for lack of a better descriptive term), but that didn't seem to help. Thanks for the help!
1994 Jeep YJ Wrangler, 1979 Ford F-150 4x4, 1949 Jeep Willy's P/U Truck |
Member # 190574
A picture would help. But most are held in by a tab, either part of the connector body, or part of the terminal itself.
Yes, there are special tools to remove terminals without damaging them. I use a few different sets from Snap-on and Matco. You can release most terminals with a small pick fairly easily.
If everyone is thinking alike, then somebody isn't thinking.
Member # 108492
Here's the style of terminal connection I'm talking about. . .the terminals in the bottom right of the photo, the three silver ones that are connected to each other
![]() Thanks!
Member # 64213
If you are trying to reuse the slot or terminal, be very methodical and figure out which way the tabs move as they each have quirks. Otherwise you'll break off the plastic lock bar on the connector.
Member # 87150
Looks like a Delphi style terminal, this should be the right extractor http://www.waytekwire.com/item/422/P...-REMOVAL-TOOL/
Paper-clips work most of the time, unless they're high end components, then the tool really comes in handy.
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE] |
Member # 108492
Thanks Maxyedor,
I've got the Waytek catalog, but I don't know enough yet to figure out which tools go to which style of connectors if I didn't buy them.
Member # 210335
If you have the tool, long thin piece of spring steel, for removing drawers on Snap-On tool boxes, you can cut and narrow one end down. Or use the eye glass screw driver as others have pointed out. I suppose an ignition feeler gauge (steel, not brass) might work if it was thick enough and if you didn't have the snap-on tool.
