Member # 177366
led light bar wiring.
I have a 6 light led bar, 5w lights. Do I need a full wiring harness with a relay and all, or can I simplify it and just run wires direct with an inline fuse? I know on KC lights and such you need a low watt side, but this is only 5w and at 14.5v that's less than an amp.
Edit: or is that 30w because I assume they're on a parallel circuit? What do y'all think? Thanks
05 TJ: The CurbJumper Last edited by WheelinOK; 06-08-2012 at 07:49 PM. |
Member # 57353
Just to clarify, you have 6x 5W LED lights mounted on a bar? That's 30W total, so 2.5A. Depending on your switch, you could get away without a relay if you really wanted to.
That said, with how inexpensive and easy to wire a relay is, I can't think of a good reason not to run one. They're cheap insurance. |
#3 (permalink) | |
Member # 177366
05 TJ: The CurbJumper |
#4 (permalink) | |
I'm a Chris Retard. |
Moderator
yes.
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
Member # 87150
Only reason I can see to run a relay is to keep positive wires away from your dash. Assuming you don't already have a bunch, in which case it's a moot point.
[QUOTE=Dieselmh;11422920]This thread is like McDonalds. It fucking sucks and doesn't deliver. :([/QUOTE] |
Moderator
Even ground wires carry current. No reason to get crazy with a 2.5a load.
Member # 87150
True, but a ground chafing and coming into contact with a ground won't hurt anything. 5 amps won't hurt anything before the fuse blows, either. However, if you already have a bunch of negative triggered relays on switches in the same area as the new LED switch, IMHO you should wire it all the same way.
Moderator
I agree, however anyone with enough electrical experience to wire up a bunch of negative switched circuits wouldn't be asking for advice on wiring in a 2.5a load
