Member # 215810
CB Ground
My friend has a 2001 Dodge 1500. We mounted a Cobra 29 LTD in his truck with a 3 foot Firestik in the bed. Our only problem is the ground... I know to ground off the mount since its top loaded. I just don't know where to run the ground wire to or what gauge wire to run. HELP
Bobbing for Fries
Member # 190574
How many times are you going to post the same question? Pick one forum and delete the rest.
If everyone is thinking alike, then somebody isn't thinking.
Member # 17870
Not knowing the specifics of your antenna and Im not reading all of this for you, I think you will find your answer here...
http://www.firestik.com/Tech_Docs.htm
Arguing with a inspector is like wrestling with a pig in the mud. After a while you realize the PIG is enjoying himself! |
Member # 25322
I'm going to piggy-back on this. one rather then start a new thread.
I've got a Cobra 19 in my ZJ, I actually just wired it today. I mounted it, along with some RG-58 (iirc) coax, a big-rig mirror mount bracket, and until yesterday, a 4' fiberglass stick a month or so ago. Yesterday I finally hit up a radio shop and bought the stainless steel 102" whip I wanted. Before I drag the SWR meter out, I need to know: I mounted the antenna bracket on my stock roof rack, which is metal, but the ends are plastic. I need to run a ground wire from the antenna bracket to the roof (or something), correct?
----In 5/16" chain we trust---- I can operate any vehicle beyond it's limits |
