Member # 140580
2 wire case grounded lights???
I wanted to keep this seperate from my thread cause it seemed weird to how my Hella's wired up.
I figured it would be a normal power and ground 2 wire hook up. No, not even ucking close... 1st I found out that you cannot run a LED indicator light on the ground side in series cause the lights will not work. My switches are on my ground side as well. I had them wired like this and the LED would light but nothing else would... ![]() Then I rewired them like this to make them work after playing with them and accidentally figuring it out when I touched the ground wire to the brush guard. I do not understand why they had to be case grounded if they have a power and ground wire going to them. It wouldnt ground to the battery but it would ground to the brush guard or the bumper, nothing else...
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
Cranky Moderator
The LED is a diode, therefore has enough resistance to not work as a ground for the lights, hence why the second method worked.
85 Toy Xtracab "I DON'T want to understand !!" Click here to donate to the Rubicon Trail Foundation Rubicon Trail Foundation "Wow this is unbelievable" 2013 Cantina for the 'Con supporters! WIN a fully built Toyota pickup at Cantina 2013 Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation We have returning Platinum sponsors for Cantina 2013 with Raceline Wheels and Falken Tires!! |
#3 (permalink) | |
Member # 62360
The second setup should work if run the wire that's going from the LED side of the switch to the battery's ground terminal, are you saying you tried that and it didn't work? To expand on what steveh said, LED's need to be current limited so they don't burn up, for small LED's this is done with just a resistor. They are limited to somewhere around 5-30 mA (depends on color/brightness). By trying to run the ground for your lights through the LED that's all the current that can pass through any point in that circuit. |
#4 (permalink) | ||
Member # 140580
After remembering that the inline LED wouldn't work I removed it from the equation and it still wouldn't light, how come they wouldn't work when grounded to the battery, frame, engine, or anywhere else BUT the bumper, brush guard, and light itself????
#5 (permalink) | |
Member # 62360
Do you have an extra light (or pigtail)? I'd be interested to know if you hook a light up straight to a battery if they light up. |
Pedal Junkie
Member # 8649
This should work as well....
Not like it matters most of the time but the long leg is typically your + lead
-Steve 43" SX, h1's, ori's, ord magnum/np205, D60/D70, lq4, th400, bentfab chassis ....some assembly required. Last edited by Mutt; 06-19-2012 at 11:46 AM. |
#7 (permalink) | |
Member # 46937
Why don't you just buy a switch that has a built in indicator light? Last edited by atblis; 06-26-2012 at 10:50 AM. |
Member # 207169
Why don't you just wire it like this???
http://www.titantalk.com/forums/atta...ch-foglite.jpg |
#9 (permalink) | |
AF6 OD
Member # 46467
![]() I bought a bag of led light holder thingy's, you just drill a 1/4 hole and pop the plastic thing in place and the led pushes in from the rear and locks into place. quick way to add a light to a switch.
73 IH Scout |
