winch circuit breaker cutting out and getting hot - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-21-2012, 07:19 PM   #1 (permalink)
Member # 213898
i just installed a superwinch lp10000 (10 000lb winch) on my chevy 1500. it came with a circuit breaker so i installed it, my problem is it keeps blowing under load. on my most recent test i put my truck at the bottom of fairly steep hill and attempted to winch up it in neutral. the winch was not working that hard i thought and it barley even got warm, however the circuit breaker was extremely hot to hot to touch for more than 2 seconds and i could not even get half way up the hill before it blew, the wire was also cool not even warm. i was winding my rope around the first layer on the drum (one layer already on the drum to be clear, NOT winding directly on the drum), so it should have still had plenty of power. im thinking of removing the circuit breaker, the starter on a vehicle is not fused so why on a winch? does anyone elses winches have breakers? anyone els not run a breaker?
4doormonster is offline   Reply With Quote
Old 06-21-2012, 10:43 PM   #2 (permalink)
Member # 130483
ditch the breaker
neither of my winches have them,I just check the wires every 6months to see if any of the cable ties broke or the wire is rubbing anywhere
92 S10,sm465/np208/np241,d44,9inch,spools,exo
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote
Old 06-22-2012, 01:34 PM   #3 (permalink)
Member # 50920
loose the breaker, wire straight to the battery.
95 DI 38s, 90 sami coils & 33's
00 F350 7.3 38' gooseneck
kbeefy is offline   Reply With Quote
Old 06-25-2012, 01:42 AM   #4 (permalink)
Off the shitwagon
SkooledMedic's Avatar
Member # 170546
either ditch the breaker or get one rated for 3-400 amps.
Being a 10k winch and probably having a "5hp" motor its gonna pull somewhere around 400amps at full load. 400amp breaker would allow you to max out the winch while still providing protection against a short circuit.
SkooledMedic is offline   Reply With Quote
Old 07-14-2012, 09:24 PM   #5 (permalink)
Member # 223802
No breaker in mine! Warn 8000 staight to batt! Lose the breaker! It wont let the amperage through creating heat!
!!Later Stacey!!
DON'T BUY BUILD!! is offline   Reply With Quote
Old 07-14-2012, 09:30 PM   #6 (permalink)
Off the shitwagon
Member # 170546
you afraid you're gonna run out of exclamation points buddy?
Old 07-14-2012, 09:32 PM   #7 (permalink)
Member # 223802
Seriously?
!!Later Stacey!!
Old 07-14-2012, 09:36 PM   #8 (permalink)
Off the shitwagon
Member # 170546
Originally Posted by DON'T BUY BUILD!! View Post
Seriously?
!!Later Stacey!!
yes seriously.
You come in here reaffirming what has already been said....for exactly what reason?
Old 07-14-2012, 09:41 PM   #9 (permalink)
Member # 223802
Only to reiterize that you were right! & this being my first posting ever on this forum, i feel welcome!! Thanks!
!!Later Stacey!!
Old 07-14-2012, 09:43 PM   #10 (permalink)
Off the shitwagon
Member # 170546
!!Later Stacey!!
You're gonna love it here if you have any questions or need anything, send a Private Message to IronPig70
if you need to buy anything PM Fatdan460, he sells all kinds of stuff. tires, wheels, engines. If he doesn't have it, he knows someone who does.
Old 07-14-2012, 09:46 PM   #11 (permalink)
Member # 223802
Thanks for the red carpet! What no champagne?
!!Later Stacey!!
Old 07-14-2012, 09:49 PM   #12 (permalink)
Member # 223802
Thanks for the heads up!! Im new to this forum, but ill catch on!
!!Later Stacey!!
