Is anybody capable of tuning the 3.5/3.9l PCMs to function as stand-alone?
I am very much so wanting to use the 3.9l "LZ9" motor for it's SUPER compact size and weight. It uses the GM 60 degree bellhousing so adapting to a manual is no problem, or using a TF904 or 700R4 is no problem either(still unsure).
I am not too keen on trying to make something like Megasquirt work to run it... especially with the variable valve timing. I'd prefer to just have a factory PCM tune run everything as it normally would... I just need a PCM that is tuned to delete shit like the transmission and all the bullshit on the CAN bus. I suppose worst case scenario I could run a later model 3.4l V6(same architecture... the new motors are based on the old 2.8/3.1/3.4) with a bit less power and torque and complexity. I am looking to shed an assload of weight from my TJ, and this would help. Even if I were to lose a bit of power, it would still probably "feel" faster with 3200lbs and 180hp than it would with 4600lbs and 190hp that it is rated at now. Anyways... does anybody know who can tune the PCM to remove extra bullshit so I can run just the 3.9l LZ9?
-Tony |
We sell stuff
Member # 189397
No personal experience with that setup, but I've used OEM PCM's before on random builds, and kept the entire CAN bus system, except for what I didn't want.
They would always throw DTC's for the missing systems, but would work fine for controlling whatever I kept in place. So auto trans, cluster, airbags, radio, etc wasn't communicating, but everything else was. The only mandatory thing is if there is a passlock/skim. You usually can't get around that. But you will have a boatload of codes. One to three for EACH missing system, and they will be current codes on every single key on cycle, so no chance of clearing them. One other option, is to buy a brand new PCM after you wire it in. Most CAN setups aren't configured at first. When you plug it in and power it up, it sends out a signal over the CAN(basically a what's up, who is here message), and each module responds that it is there. If it doesn't see a module the first time you plug it in, it doesn't know any better, and never knows to look for that specific module. Every time you power it up, it looks for new modules, as well as the specific modules it has seen before. Manufacturers do this so they can use one PCM program over a huge variation of options. I know for a fact that this works with SOME PCM's, because it has been used to bypass the need for a SKIM/Passlock type sensor. I also know that if one day you plug/wire a new module into the CAN, it will always look for that module from that point forward, even though it didn't before. Back in the day, I inadvertently activated the SENTRY system on a Chrysler that didn't come with it. One that according to Chrysler, wasn't SENTRY capable. I had to wire in the full setup and have the guy switch to a SENTRY key for his ignition, otherwise the car wouldn't start. Again, I have no personal experience with that exact PCM, so I can't promise it works that way. Best thing to do is talk to a GM Master tech and ask him about PCM's learning the CAN bus system.
American Rock Rods 303-400-0205 New website coming soon! www.americanrockrods.com |
#3 (permalink) | ||
FWIW I emailed HPTuners and got this reply back: Quote:
-Tony |
