Soldering CB cable ends - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-13-2012, 05:27 PM   #1 (permalink)
grnd93's Avatar
Member # 64925
Send a message via MSN to grnd93
Plan on installing the CB in my TJ soon. My plan is to make an antenna mount to bolt in place of the spare tire carrier on the tailgate and run the cable through the grommet where the 3rd brake light wiring ran. To do this I have to cut an end off the antenna cable and solder a new one on. I picked up the cable, stud mount and replacement end today. Anybody have any tips to make this go easier for me?
Originally Posted by void_of_light
Somewhere in the Canadian wilderness, the new owners are questioning their decision to buy a forum filled to the brim with assholes.
grnd93 is offline   Reply With Quote
Old 07-13-2012, 06:44 PM   #2 (permalink)
Member # 221016
Here's a how to
http://www.stu-offroad.com/misc/rfconn.htm
87slosohc is offline   Reply With Quote
Old 07-13-2012, 07:10 PM   #3 (permalink)
grnd93's Avatar
Member # 64925
Originally Posted by 87slosohc View Post
Thanks, found that with my googlefu (after posting here).
I just gotta get a chunk of angle iron to make the mount and I'll be giving it a shot.
Old 07-14-2012, 07:36 AM   #4 (permalink)
machinisttx's Avatar
Member # 220625
I'd suggest trying to find compression style or crimp style PL 259 connectors instead of solder type. http://www.eham.net/articles/19257
I've soldered on N type connectors and it's a little tricky to get enough heat without getting so much as to melt the coax and short from the center conductor to the outer shield. Crimp and compression fittings are much faster and easier to work with. Also, be sure to buy the right size for the coax you're using. You may have to buy a reducer sleeve as well.
machinisttx is offline   Reply With Quote
Old 07-14-2012, 08:33 AM   #5 (permalink)
grnd93's Avatar
Member # 64925
Any signal loss or any thing with the crimp on?
Old 07-14-2012, 09:12 AM   #6 (permalink)
pepe's Avatar
Member # 17870
Check your cable end, most have a smaller end on the cable that screws into a larger end that fits on your CB.
Arguing with a inspector is like wrestling with a pig in the mud.
After a while you realize the PIG is enjoying himself!
pepe is offline   Reply With Quote
Old 07-14-2012, 09:46 AM   #7 (permalink)
grnd93's Avatar
Member # 64925
Reading about the crimp on end...the ends are cheap but the crimped is pricey. I do have a radio shop a few miles from me, maybe I'll run the cable then drive it over there and have them put the end on. I can have them adjust my SWR while they're at it.
Old 07-14-2012, 10:58 AM   #8 (permalink)
Member # 220625
With crappy connectors or a bad crimp, probably. With good connectors and a good crimp there shouldn't be any difference between them and a soldered connection(except the amount of work). Read more on the eham site and you'll probably find out more than you wanted to know about coax cable and connectors.
A type "N' connector is weatherproof and preferable to the standard PL 259, but I'm not sure if any CB antennas are made for them.
