4.0 liter obd1 stand alone wiring harness - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-03-2012, 10:23 AM   #1 (permalink)
Member # 179969
Just had Jim aka Satan on this board cut down my wiring harness for my 4.0 swap. He did one hell of a job so if u need this process done to convert ur harness to a four wire stand alone harness hit up Satan aka Jim brooks with the devils workshop.
The Goat 812 is offline   Reply With Quote
Old 08-03-2012, 05:08 PM   #2 (permalink)
Nocturnal Creature
SATAN's Avatar
Member # 110292
Thanks Mr. Goat.
Hope she runs good.
Come party sat.
K5,tube body,383TPI,D60-detroit,14b-spool,shaved,5.38,39.5 IROK,full hydro.
SATAN is offline   Reply With Quote
Old 08-15-2012, 03:57 PM   #3 (permalink)
Member # 226171
I need to have my harness built or use the 92 xj harness to work in my 95 yj.. from what i find you are the man for this job..
BADCOMPANY95 is offline   Reply With Quote
Old 08-16-2012, 11:20 AM   #4 (permalink)
Member # 179969
Send Jim a pm he can hook u up.
Old 08-16-2012, 12:05 PM   #5 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
Need to post this in nonhardcore.
RANGERROD is offline   Reply With Quote
Old 08-16-2012, 12:15 PM   #6 (permalink)
Weasel's Avatar
Member # 5639
Um this is the electrical forum so I'd say it in the right place. A stand alone harness isn't exactly a bolt on buy it from quadratec type of modification.
Just Add Lightness
I'd rather be simple-and-wrong than complicated-and-wrong.
Weasel is offline   Reply With Quote
Old 08-16-2012, 03:18 PM   #7 (permalink)
Nocturnal Creature
SATAN's Avatar
Member # 110292
What I do is cut down the factory 92 style Cherokee harness to run in a buggy or whatever.
I can get a harness for you or use yours.
You end up with 3 wires to hook up. 12v constant. 12v switched. Ground.
I also do early GM TBI and TPI harness.
I can help any who wish to do the harness themselves as well.
Old 08-16-2012, 06:42 PM   #8 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
Wasn't saying wrong forum just saying people in jeep non hardcore might be interested. Carry on.
Old 11-25-2012, 09:50 AM   #9 (permalink)
Member # 108456
Jim,
I've got a 2001 Jeep TJ with 4.0 & 32RH Auto trans. I'd like to eliminate all of the emissions crap on the harness. There's a number of wires running to them. Could you modify my harness so I can remove this stuff? Or is there something simple I can do myself to make these deletes possible without affecting how my engine runs?
Thanks,
Daniel
dannyz14 is offline   Reply With Quote
Old 11-25-2012, 03:18 PM   #10 (permalink)
New Beginnings
jpfrk2001's Avatar
Member # 99513
I could use your help. Im working on a buggy right now. I do have the factory ECU and Factory harness with engine bay fuse box. I would love to dumb it down to what you say..I want to be able to start/run the motor as soon as possible.
Soo.. Whats first step?
jpfrk2001 is offline   Reply With Quote
Old 01-15-2013, 07:09 AM   #11 (permalink)
Nocturnal Creature
SATAN's Avatar
Member # 110292
Sorry but I don't get much time to check the Internet. If you need my help please pm me because it will email me and I will check it.
Thanks.
Jim
Old 05-20-2013, 08:57 PM   #12 (permalink)
Member # 280658
did my own, works good
its not so hard to do as confuddlling as F*$K the important thing to do is get comfy,(take the harness out and bring it inside to the dinning room table, Lots of room to spread her apart there)
I didn't cut a stock xj harness down as there was just soo mush wire I new I wouldn't need! I ended taking the 1993 zj harness and splicing part of it (the pcm and injectors were all in one nice little package) into a 4cyl yj harness.. pin 3 on your pcm is direct fused 12v and there are two grounds pins I believe pins 11,12 i dont have the diagrams in front of me bit but i believe the keyed ignition wire goes to pin 9 of the pcm connector there are your three wires to hook to your buggy........... good luck guys, and search around I found a pdf file for all eclectrical diagrams for yj's and xj's very useful in this line of work...
Be Radical is offline   Reply With Quote
