03 GMC Yukon Battery Drain - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-15-2012, 07:50 AM   #1 (permalink)
Member # 125043
I have a Yukon XL that I'm not sure if the battery is being drained by something or if my less than 2 year old Delco battery is going to crap. I have a large Fosgate amp hooked into the factory radio and an Ipod adaptor. I just need to know the best way to check and see why I get left with a dead battery. I have a Fluke multimeter but lack in the electrical knowledge to go about what to do and am asking for some suggestions as to where to start.
HappyGilmore is offline   Reply With Quote
Old 08-15-2012, 08:28 AM   #2 (permalink)
J P
J P's Avatar
Member # 121424
Start by disconnecting your neg. battery cable turn everything off, pull the fuse to your radio ( they draw a little juice always / clock ) put a test light as a jumper between neg cable and battery if the light is on you have a draw . start unpluging fuses until the light goes out , when the light goes out you found the draw ! ALL DOORS , HOOD anything that makes a light come on have to be off/ closed .
J P is offline   Reply With Quote
Old 08-15-2012, 08:48 AM   #3 (permalink)
MTMudpuppy's Avatar
Member # 126578
The only problem doing it that way is you are always going to have phantom drains on a newer rig like that. Computer, clock and such.
A better way to do it would be to charge the battery up on a manual battery charger till it gets warm to the touch. Let it cool over night and check the voltage. Should still be somewhere around 12.8 or higher. If it is considerably less then the battery is dying. If the lights got left on once, for instance, and driving around in the car charging it with the alternator, it would never get charged up and continue to die over night. Good luck. I doubt it is the battery.
1988 4runner, duals, V6, 36's, and some other stuff
2004 chevrolet 2500HD, 6.0, tow pig!
MTMudpuppy is offline   Reply With Quote
Old 08-15-2012, 09:10 AM   #4 (permalink)
Member # 125043
Thanks guys I will do some work tonight and in the morning checking on your reccomendations.
Old 08-15-2012, 09:29 AM   #5 (permalink)
Bobbing for Fries
billy bones's Avatar
Member # 190574
The most accurate way is to use your multimeter.
It is outlined here:
http://www.pirate4x4.com/forum/showp...91&postcount=2
flatlander757 did a good job of explaining this, and I'm too lazy to retype it.
If everyone is thinking alike, then somebody isn't thinking.
billy bones is offline   Reply With Quote
