LED light bar BEHIND the windshield? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-26-2013, 05:02 PM   #26 (permalink)
Member # 75114
Originally Posted by Seabass View Post
I have a buddy who works with rigid. Once my bank account recovers from the giant wave of bills that hit me this last month I'll start bugging him about heat output. Theres no sense in me bugging a whole bunch of people if I can't pull the trigger on buying from them.
So, you are going for the RDS-Series Light Bars then I presume?
keeptahoewhite is offline   Reply With Quote Quick reply to this message
Old 11-29-2013, 04:40 PM   #27 (permalink)
Member # 175582
I mounted mine inside of the windshield down low in front of my spreader bar. Its on a TJ but the concept is the same. I thought I would need some kind of foam rubber gasket for glare but was surprised to find out the glare wasn't bad at all. It's a Fenix 30" single row. Very low profile. It looses very little, if any lumen output shining through the windshield.
If it drives, flies, floats, or fucks, it is cheaper to rent!
I should start taking my own advice...
mitaker is offline   Reply With Quote Quick reply to this message
Old 04-15-2014, 09:17 AM   #28 (permalink)
Member # 51990
Anyone else have any more input on this? Thinking of mounting a 52" or whatever I can fit inside off my internal cage. Basically off top roof bar hanging down so it's protected and I don't have to do anything awkward outside truck. Curious about heat and glare.
"I like it better when you don't pay your Internet bill."
twistedtruck is offline   Reply With Quote Quick reply to this message
Old 12-06-2014, 07:54 AM   #29 (permalink)
Member # 24876
Anyone try this?
[COLOR="Lime"]'85 Toyota ext cab. 4 cyl. 5.29s. Chromoly birfs. dual cases. hi-steer. OBA. front ARB. rear welded. cage.[/COLOR]
FullsizeYota is offline   Reply With Quote Quick reply to this message
Old 12-06-2014, 09:23 AM   #30 (permalink)
J P
J P's Avatar
Member # 121424
Would the heat difference on the glass cause the glass to fracture ?
J P is offline   Reply With Quote Quick reply to this message
Old 12-08-2014, 01:17 AM   #31 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
That's a good question.
I'm gonna guess* that it's not any worse than the hell we put our windshields through, -40 outside and the defrost blowing hot air at the bottom of the windshield.
*I don't have any experience at all with led bar heat output.
GO MINING
Good luck and remember, if you're not awesome, don't worry, because I'm FUCKING awesome!!
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 12-08-2014, 06:13 AM   #32 (permalink)
KacksterK5's Avatar
Member # 5851
That glare from the TJ windshield would drive me insane
02 Chevy 2500 HD Tow Rig
KacksterK5 is offline   Reply With Quote Quick reply to this message
Old 12-09-2014, 12:23 PM   #33 (permalink)
Subybaja's Avatar
Member # 206384
which adds up to about 70% of the windshields in Ak having a horizontal crack 6" from the bottom...
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 04-04-2015, 03:00 PM   #34 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
Did this ever get done?
I swear sometimes this place should be called "Autism on bath salts".
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 04-04-2015, 06:26 PM   #35 (permalink)
MSC
Member # 545890
I would think if you had a crack or rock chip in your view it would be like looking into the light itself. When you shine light through glass doesn't it travel to the edges of the glass, cracks and chips?
MSC is offline   Reply With Quote Quick reply to this message
Old 04-04-2015, 07:53 PM   #36 (permalink)
Seabass's Avatar
Member # 49159
Not by me. I've been making grown up decisions for the last year and a half and it sucks. Truck has been in storage for at least that long. My next super sweet mod to it will be registration and a tank of fuel
Engineer (en•gun•eer) Definition: A man that would pass up ten naked blondes to fuck a mechanic.
Seabass is offline   Reply With Quote Quick reply to this message
Old 01-15-2017, 02:44 PM   #37 (permalink)
Member # 668425
42" mounted to cage behind windshield, lots of glare with windshield on I wheel with windshield off most of the time so not a factor for me
colaman24 is offline   Reply With Quote Quick reply to this message
Old 01-24-2017, 01:38 PM   #38 (permalink)
Member # 513154
decent idea but i think the windscreen will defuse the light because of the angle and throw it everywhere limiting how far you can throw a beam. Keen to be proven wrong though
jgrov2 is offline   Reply With Quote Quick reply to this message
Old 03-17-2017, 12:23 PM   #39 (permalink)
Member # 65971
LMAO, it's the only place you should ever mount a light bar. Unless you like wind noise, drilling holes in the roof to mount/wire it, climbing your truck to keep it clean, or having thieves destroy your truck when they take it...
I installed mine behind the windshield because people told me it was a stupid idea...
Easy to keep clean...
My wipers aren't even lit up never mind the dash...
The light output is not compromised to the point your eyecrometer will ever notice...
Fords flex A LOT. I actually use mine off road and because of the flexing my windshield cracks from time to time. I am lucky they are still inexpensive. When the light shines through the cracks you can see a greenish line in the glass, but that’s about it…
Without the light bar up top I can still fit in places where it is already difficult with a lifted truck…
As far as heat is concerned, it’s not an issue. The optics are plastic and the light is shooting through a plastic lens. None of that melts. The heatsink on the back gets warm, but it’s not going to set your sun visors or headliner on fire. If your kid grabs it accidently he/she won’t get burned.
If you mount it inside get ready to answer lots of questions when you are out and about. You will also have fun talking to know-it-alls that will tell you it’s a stupid idea until you turn it on for them and show them how stupid it really is.
1997 F350
lovesdunes is offline   Reply With Quote Quick reply to this message
Old 03-17-2017, 11:07 PM   #40 (permalink)
Will_v2lab's Avatar
Member # 724426
Beautiful truck man. I actually like the idea of an interior bar. I've hesitated getting led bars for my Ram and my Tahoe but always hated the thought of people stealing them. Its not as bad now that I dont live in Las Vegas but I just learned to not trust people.
Will_v2lab is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 06:05 PM   #41 (permalink)
Member # 65971
Thanks. We have had the truck for over 15 years. I can't say enough good things about it.
It sucks that one of things people have to think about when mounting lights is if someone is going to steal them or not. But I guess we always have to keep that in mind when adding things to our trucks.
1997 F350
