LED light bar BEHIND the windshield? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2013, 05:53 PM   #1 (permalink)
Seabass's Avatar
Member # 49159
Thinking about what it would take to mount an led bar behind the windshield INSIDE the cab at the very top of my windshield. I know some cop cars have the strobes inside the cab. Anyone know what the enclosures look like? sheet metal with foam seals?
I know it'd be easier to mount on the ouside and wouldn't look bad but I'd like to continue the sleeper status on my build. Here's what it'd be going in.
Engineer (en•gun•eer) Definition: A man that would pass up ten naked blondes to fuck a mechanic.
Seabass is offline   Reply With Quote Quick reply to this message
Old 05-20-2013, 09:23 PM   #2 (permalink)
Member # 82124
Now thats retarded!!!!!
You should mount it facing rearward so you can burn your eyeballs out and then walk into on comming traffic.
Wow people are really that stupid?
85 reg cab long bed 22re, auto, AP extreme kit, lock rights on 36's
megadesertdiesel is offline   Reply With Quote Quick reply to this message
Old 05-21-2013, 12:06 AM   #3 (permalink)
Seabass's Avatar
Member # 49159
Yeah I'm really that stupid.... wanna tell me why this idea is so retarded?
Old 05-21-2013, 05:12 AM   #4 (permalink)
bobbing for fries
billy bones's Avatar
Member # 190574
It seems like a good idea, one less thing to be broken off or stolen.
You are correct, a sheet metal housing with foam or rubber seals. I will try to get a picture for you.
Until then ...
Whelen Engineering - Lightbars - Val-U-Bars™ and Mounting Kits
If Everyone Is Thinking Alike, Then Somebody Isn't Thinking
billy bones is offline   Reply With Quote Quick reply to this message
Old 05-22-2013, 09:03 AM   #5 (permalink)
bobbing for fries
Member # 190574
A few pictures of how they look installed on a pickup. You could build a similar housing or shroud to fit most any commercially available Led light bar. This one doesn't have a seal around the windshield area, but you get the general idea of how it works and fits .
Old 05-22-2013, 05:48 PM   #6 (permalink)
Seabass's Avatar
Member # 49159
Awesome! Thanks for the pictures! Im wondering how much deflection the windshield causes when trying to focus and aim. Im gonna have to borrow a small bar and play around a bit.
Old 05-22-2013, 06:04 PM   #7 (permalink)
Member # 75114
in for when you get it set up.
keeptahoewhite is offline   Reply With Quote Quick reply to this message
Old 05-22-2013, 06:20 PM   #8 (permalink)
0[III]O
Redfin's Avatar
Member # 132064
What's so retarded about it? Other than the possible glare (which could probably be solved with some type of foam surround) I think its a glorious idea.
With led's you would not have to worry about heat and in a fullsize rig there is plenty of room if you keep it tucked high to the roofline.
Build it up sir. I want to see what it shows.
BUY MY
Toy/Lexus 3.0 clutch...
Bendix Tuflo compressor
I NEED
Cadillac 425 rear sump pan
Redfin is offline   Reply With Quote Quick reply to this message
Old 05-23-2013, 05:23 AM   #9 (permalink)
bobbing for fries
Member # 190574
Even without a foam surround and the blue/reds strobing away at night, glare is minimal. The only issue I see would be beam pattern cutoff along the lower edge due to the long bottom shroud. Probably best to stick with a spot lens, or angle it down slightly. The range will be reduced slightly, but that should be ok for most vehicles.
Another vote for build it.
Old 05-23-2013, 09:59 AM   #10 (permalink)
Weasel's Avatar
Member # 5639
I want to see this done, I think it's a good idea!
Experience is what you get 30 seconds after you need it
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 05-23-2013, 12:02 PM   #11 (permalink)
Member # 75114
Cutting off the beam on the bottom sounds like a benefit with that white hood.
Maybe 2 separate bars would be better, one on either side of the rear view mirror? Similar to:
Old 05-23-2013, 01:17 PM   #12 (permalink)
89breaker's Avatar
Member # 64213
I don't think you are going to get projected distance behind the glass.
89breaker is offline   Reply With Quote Quick reply to this message
Old 05-23-2013, 03:27 PM   #13 (permalink)
Seabass's Avatar
Member # 49159
I dont like splashback from roof lights hitting the hood. I've had a bit of seat time in a truck with two 40"s on the roof. The long shroud on the bottom woul be benifitial like some of you mentioned. The two 10"s in the grill ar spots so the large bar or 2 or 3 small bars I think id fit with combos. Tracing the pattern for the shroud is gonna be a son of a bitch. ...
Old 05-23-2013, 05:51 PM   #14 (permalink)
bobbing for fries
Member # 190574
It won't be too difficult. Build a mockup out of poster board. Use a transfer scribe (google it, easy to make) to trace the contour of your windshield.
Old 05-28-2013, 09:36 PM   #15 (permalink)
Member # 29341
I can tell you my light bar as well as my dually d2's emit plenty of heat.
supersize75k5 is offline   Reply With Quote Quick reply to this message
Old 05-28-2013, 10:57 PM   #16 (permalink)
W6FTW
NorCalPR's Avatar
Member # 133266
X2, trace from the outside of the glass. Just hold up to the glass and have marks, and how far the glass is away from that mark at a 90 degree angle.
Then just measure, mark, connect the dots and cut. You'll have a mirror image of the glass.
Interested to see how this works out. My truck is a DD and stays outside all the time and theft is the number one reason I haven't gone to LED's. I also like the sleeper look
NorCalPR is offline   Reply With Quote Quick reply to this message
Old 06-18-2013, 04:33 PM   #17 (permalink)
bigtoy302's Avatar
Member # 36440
I would not do this. A: LEDS make a ton of heat and B: You will loose light output going through another layer of glass. Over 10%
Led bars need a good amount of airflow to stay cool. If they get too hot they will start cutting current(light output) to stay cool. They can reach temps upwards of 165F. I sure would not want that in my cab.
bigtoy302 is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 09:03 AM   #18 (permalink)
Member # 7290
You sir....need to STFU.
I think its a great concept Seabass.....but I'm afraid...
This is probably the answer you don't want to hear. High output lighting gets hot, regardless of the source. And a big badass lightbar is going to be no exception. It might not be so bad if you've always got the defrost A/C going, or windows down or something...
but, heat....you will notice it.
--B
Shaffer Motorsports - 1066
Thanks to: Transfercases Express, PowerTank, Shaffers Offroad
Berne is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 04:02 PM   #19 (permalink)
ISDTBower's Avatar
Member # 94026
Inset them in your roof line with appropriate shield to prevent glare on the hood? Just work.
ISDTBower is offline   Reply With Quote Quick reply to this message
Old 06-21-2013, 05:48 PM   #20 (permalink)
bobbing for fries
Member # 190574
Seabass, any updates?
Old 06-22-2013, 12:34 PM   #21 (permalink)
Seabass's Avatar
Member # 49159
I have a buddy who works with rigid. Once my bank account recovers from the giant wave of bills that hit me this last month I'll start bugging him about heat output. Theres no sense in me bugging a whole bunch of people if I can't pull the trigger on buying from them.
Old 06-26-2013, 08:00 AM   #22 (permalink)
crawlin78's Avatar
Member # 211417
The heat out put on rigids is nothing compared to a holigin light. I have @ 50 inch 20 inch and a bunch of dullys scattered accross my vehicals. I can hold my hand on the lights while they are on.
Btw this sounds like somthing im going to try !! Good idea
Guns don't kill people its mostly the bullets!!!!!!! So don't get it twisted
crawlin78 is offline   Reply With Quote Quick reply to this message
Old 11-23-2013, 08:56 AM   #23 (permalink)
Member # 392202
I install these on police and Marshalls for a living and they work perfectly. You just need to buy quality. LEDs do not get hot. You will be mounting off your visors. They perform very well. You just have to mount it close enough to the glass that you don't get light reflecting back but not so close that it rattles. Go with code 3 or federal signal. They both make very good solutions. I have seen them light up a city block. I will put it this way. If it didn't work, the Marshalls wouldn't spend 10s of thousands on us to install them.
Led pro is offline   Reply With Quote Quick reply to this message
Old 11-26-2013, 03:56 PM   #24 (permalink)
Member # 208882
Here is a new Police vehicle interior lightbar, that has both a warning and takedown (flood) mode. This has the shrouding like the other interior lights, but they use the shroud as a heat sink as well. If you look at the second photo you can see that the board is sitting on the bottom of the shroud, and it uses a reflector to project the light. This uses six 3 watt LEDs per module, and works very effectively as a flood light.
Here is a Video showing this as well.
SoundOff nFORCE Interior Lightbar - YouTube
1989 Toyota Landcruiser FJ62
Sirennet is offline   Reply With Quote Quick reply to this message
Old 11-26-2013, 04:37 PM   #25 (permalink)
bobbing for fries
Member # 190574
We use those style led strobes on customer vehicles all the time. I, and I think the OP, are more interested in using this as a constant "ON" driving lamp.
More interested in seeing, rather than being seen.
