wiring 5050 led? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2017, 02:05 PM   #1 (permalink)
STHM
nycreecy's Avatar
Member # 196079
wiring 5050 led?
I want to use this Lerway led strip as a dome light. I removed the 2 connectors, connected the +&- wires on one end together, connected the wires on the other end to 12v battery (+ to +, -to-). The led strip got hot and the wires start to melt. The strip has 18 LEDs and each has a resistor with "151" printed on it.
Was I supposed to use an additional resistor?
Is this the wrong type of LED?
How should it get wired?
Thanks,
Chan
nycreecy is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 11:01 AM   #2 (permalink)
gumboot cloggeroo
Muckin_Slusher's Avatar
Member # 467233
Thanks,
Chan
There's yer trouble.
GO MINING
Good luck and remember, if you're not awesome, don't worry, because I'm FUCKING awesome!!
Muckin_Slusher is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 12:11 PM   #3 (permalink)
STHM
nycreecy's Avatar
Member # 196079
IOU a
Thanks
Old 06-18-2017, 03:08 PM   #4 (permalink)
gumboot cloggeroo
Member # 467233
Just cap them off so they can't short together or touch anything. Fold over the wires and use a piece of heat shrink.
By shorting those two wires together you created a dead short, just like putting a wire across the terminals on your battery-----------4-500 amps or more. Sounds like you had it on a circuit in your truck, so the current would be up to what your fuse was at.
These LED lights come with the smallest wire possible, not capable of carrying any extra current, so they smoke pretty easy.
GO MINING
Old 06-19-2017, 08:54 AM   #5 (permalink)
Member # 343737
your bigger problem is this
wires should be fused to protect the wiring
_ogre is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 09:11 AM   #6 (permalink)
STHM
nycreecy's Avatar
Member # 196079
Thanks. Now they are on the fused dome light circuit. I was just testing them with a spare battery to make sure they worked b4 installing.
