Marine 454 MPI Fuel Injection - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 10-11-2004, 06:22 PM   #1 (permalink)
Member # 16263
Complete multi-port fuel injection system off of a 7.4 liter 454 mercruiser. This is a stand alone system. All it needs is fuel and 12 volts. The wiring harness, computer, ect is mounted to the engine. This is complete with everything you need to upgrade your 454 or 502 to fuel injection except for the distributor.
These units are very heavy duty. The are designed to run in hot, wet conditions. Much better than the aftermarket crap that quits at the wrong time.
I was going to run this set up, but I ended up buying a whole '99 mercruiser motor and will not need this other set up.
$1000
In wooden box the whole unit weighs about 110-120 lbs. I can ship it at your expense from zip 37830. This in near Knoxville, TN.
Trying to save the earth from Green Peace, one environmental wacko at a time!
treehuggerssuck is offline   Reply With Quote
Old 10-13-2004, 04:02 PM   #2 (permalink)
Member # 34181
Is This For A Rectangular Port Or Round Port Head?
kodiak77 is offline   Reply With Quote
Old 10-13-2004, 04:04 PM   #3 (permalink)
Grendel's Avatar
Member # 10448
Send a message via Yahoo to Grendel
I am interested as well.
Grendel is offline   Reply With Quote
Old 10-14-2004, 04:49 PM   #4 (permalink)
Member # 16263
454 injection
This is rectangle port. However, some of marine motors had oval port heads on them with the same set up. I know it doesn't make much sense (rectangle port intake and oval port heads) but Mercruiser did it.
Let me know if you have any other questions.
Brent
865-494-5499
Old 10-14-2004, 04:55 PM   #5 (permalink)
jac6695's Avatar
Member # 24174
Not interested, but isn't that setup close to the same as used by GM on the 502 Ramjet? I know they look similar. BTW, I have heard good things about this system, and for the money, a good option to a relatively rare 454 TBI system.
James 86 S10 Blazer LT1/4L60E/203/205 Doubler/D60/14B
11 Chev Silverado Dmax, 97 GMC 2500HD 6.5
jac6695 is offline   Reply With Quote
Old 10-17-2004, 07:17 AM   #6 (permalink)
Member # 16263
not sure
I'm not sure what the ram jet system uses. What were they in?
Old 10-17-2004, 08:31 AM   #7 (permalink)
Grendel's Avatar
Member # 10448
DOes the computer run the distributor?
If so, what kid of distributor does it require?
Old 10-18-2004, 07:27 AM   #8 (permalink)
Member # 16263
distributor
The computer runs the distributor. I have the right distributor for it. Everything needed is there excepter things like plug wires, distributor cap, coil, ect.
Old 10-18-2004, 08:44 PM   #9 (permalink)
jac6695's Avatar
Member # 24174
The 502 RamJet is a crate engine from GM. Try this link:
http://www.paceparts.com/
I read somewhere that the intake is the marine intake like you are selling. That info could be wrong, though. Does your system have a Mass Air Sensor?
Old 11-18-2004, 11:21 AM   #10 (permalink)
Member # 16263
still got 'em
I've still got 'em
Old 11-18-2004, 07:45 PM   #11 (permalink)
Member # 33504
Shoot me some pics. qwkrnu351w@aol.com
STANGJEEPER is offline   Reply With Quote
Old 11-21-2004, 07:10 AM   #12 (permalink)
Member # 16263
pictures
Pictures have been sent
Old 11-22-2004, 07:35 PM   #13 (permalink)
Member # 34221
could ya send me some pics too please, to...dammit0001@aol.com
ftwK5 is offline   Reply With Quote
