Chevy 388 stroker built short block in Nor Cal - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 01-05-2006, 09:30 AM   #1 (permalink)
Member # 40827
This engine is a 388 stroker and the block was checked through and through to make sure it was safe for a .060 overbore. it was in a 70 chevelle and pulled when it began to smoke a bit, turns out the heads needed new valve guides and motor was perfectly cherry.
Magnafluxed
Balanced + Blueprinted
Balanced with the flexplate and harmonic balancer. no vibes, this thing revs very smoothly, and is very torquey and snappy.
Custom Keith Black pistons
268H comp cam (great cam for off-road)
4 bolt main, all new bolts
new oil pump, high volume with light spring. High volume, low pressure.
with 76cc heads it was 9.8:1
zero decked block
moly rings
fel pro bearings
windage tray
it has 80k miles on the shortblock.
make me an offer, this will cost you $1600 to reproduce at a shop.
asking $900
Give me a call 707-484-0148
not really interested in trades except for 39-42" tires for 17" wheels, seats, harnesses, atlas II, 16"coilovers or airshocks.
5.9 Jeep 1998 Limited
ptownTSI is offline   Reply With Quote
Old 01-05-2006, 02:57 PM   #2 (permalink)
Member # 63873
So has the motor been rebuilt or just freshened up? Did you bore the motor 60 over? Thanks
extd56 is offline   Reply With Quote
Old 01-05-2006, 04:48 PM   #3 (permalink)
Member # 40827
It was completely built/bored/machined/blueprinted/balanced etc 80k miles ago. it doesnt need a freshening up. runs like a dream, the thing is just getting broken in. My uncle went with something else in his chevelle, and asked me to sell his short block for him. He's technologically retarded when it comes to the internet.
He had another engine at his house so he pulled this one, put the new one in, and then figured out later that this one was still perfect. sucked for him, its better than the one he has in there, but the works already done so this one is up for sale.
yes, it was bored .060 over. the block was checked for core shift and everything, it was a very sound block. no problems with overheating, or thin walls.
thanks for asking.
