GM Performance RAMjet Crate Engine - New - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 02-15-2006, 09:21 PM   #1 (permalink)
Member # 3864
Send a message via AIM to WOLF359
New, never turned over, never installed RAMjet Crate Motor
Manufacturer: GM Performance Parts
Horsepower : 350 hp @ 5200 rpm
Torque : 400 ft lbs. @ 3500 rpm
Compression Ratio : 9.4 to 1
Block : Cast Iron 2-Bolt, 4.000" Bore
Crankshaft : Nodular Iron, 3.480" Stroke
Heads, Chamber Size : Vortec, 64cc
Valves (I/E) : 1.940"/1.500"
Camshaft, Lift (I/E) : 0.431"/0.451"
Dur. @ 0.050" (I/E) : 196/207 degrees
Intake : Ram Jet PFI
Comes complete (5 wire hookup), includes new in boxes distributor, coil, wires, MEFI 3 harness, MEFI 3 ECM, flywheel, diagnostic tool, manual, all sensors.
In addition, I will add the following: A complete NEW IN BOX MEFI 4 harness and computer, + auto transmission flexplate.... (the MEFI 4 harness and computer retails for $1400)
So you have a complete RAMjet MEFI 3 backup harness and ECM in addition to MEFI 4.
$7300.00 cdn
Engine is available for pickup only in Calgary, Alberta.
403-221-9499 days
403-277-6735 evenings
wolf359@shaw.ca
Here are some pictures taken when I opened the crate, the engine has been in the garage for the last year. I don't have the crate, but I will supply it on an engine stand.
WOLF359 is offline   Reply With Quote
Old 02-16-2006, 01:47 PM   #2 (permalink)
Marion Cobretti
72blazer's Avatar
Member # 40131
...$7300? wow...good luck...
The Web Wheeler's '72
Motorsport Syndicate:::Edinburg TX
H&H Fabrication:::Amarillo TX
72blazer is offline   Reply With Quote
Old 02-16-2006, 02:01 PM   #3 (permalink)
Member # 3864
canadian dollars
