Member # 81158
WTS:TERA LOW231 HD transfer case & Tera 2LOW231
I have a brand new Tera Flex Manufacturing "Tera Low" 4:1 transfer case kit that is still bolted to the board in the box.
Part# LOW231-21 fits 4 cylinder Manual Transmission Jeep Wranglers & Cherokees. The Tera Low231 conversion kit is the solution for providing Wranglers, Cherokees, and Comanches with low crawl ratios. This kit provides rock-crawling performance without affecting high range gears for daily drivers, or the trip to and from the back country. It provides a true 4.0:1 reduction through a 5 gear HD planetary system. Every part in this kit is new, with no core charges. Shift linkage and driveshaft length changes are not necessary. The Tera Low231's high input torque rating will handle extreme torque applications. Each Low231 is covered with our exclusive two-year warranty. The Tera Low231 is compatible with the 2WD Low-Range Shift kit (Part #2LOW231), the TeraLow Extreme Short Shaft kit (Part #231ESS), and the Short Shaft kit (Part #231SS). Note: Some Cherokees require one-quarter inch to be removed from the end of the input shaft in order to function properly. Please specify when ordering. 241/242 t-cases: Call us for details on using our low-range gearing in 241 and 242 transfer cases. Note: Because these low-range gear sets increase torque by up to 50 percent, some large or high-performance engines may contribute to premature drive train failure. ![]() I also have a new Tera Flex Manufacturing "Tera 2Low" kit that will be included. Part# 2LOW231 fits 6 or 4 cylinder Jeep NP231 transfercases in Wrangler, Cherokee or Grand Cherokee. The 2Low kit provides the benefit of true low range gearing, while allowing the front to freely turn. It lets you choose 2 Low in addition to the other standard options. The 2 Low kit will eliminate drive train bind and most of your three-point turns. This kit is completely internal and does not require any external modifications. ![]() These are great products for your rock crawler project. I will take $1025.00 for both items shipped to an ARIZONA or NEW MEXICO address. Any where else we split the shipping. I WILL NOT SPLIT THEM UP !!! I have posted these on eGay if someone takes them here I will end the auction. Thank you for looking, Phessor
