The ultimate T-18 combo!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 11-10-2006, 06:22 AM   #1 (permalink)
Shameless Racing
rolloverboy's Avatar
Member # 82154
SOLD
Lakewood explosion proof chevy to jeep bell housing/T-18 6.32:1 1st gear/dana 18 T-case $500 -- the input shaft and bearing retainer have been shortened 1/2" and it uses a stock chevy T.O. bearing -- this combination must be used behind a chevy motor or you will need a new input shaft
SOLD
rolloverboy is offline   Reply With Quote
Old 11-11-2006, 08:16 AM   #2 (permalink)
Member # 38965
consider selling seperate? Looking for a chevy Bellhousg to fit behind my Jeep T 18
scoutphanatic is offline   Reply With Quote
Old 11-11-2006, 01:14 PM   #3 (permalink)
Shameless Racing
Member # 82154
I'd let the bell housing go for $275, but you may need to modify your input shaft. Check out 4wd hardware part #2439; this is the bellhousing which fits the T-18 just fine with the addition of one half inch nut welded in for it's bolt pattern. The bearing retainer has the same diameter but my T-18 input shaft and retainer were about 1/2" too long (hit the clutch fingers). It's a fairly simple mod.
Old 11-14-2006, 06:44 AM   #4 (permalink)
Shameless Racing
Member # 82154
Smile
top
Old 11-14-2006, 03:28 PM   #5 (permalink)
Member # 72816
willing to ship? let me know to 84003. what condition are the units in?
1949cj3a is offline   Reply With Quote
Old 11-14-2006, 05:32 PM   #6 (permalink)
Shameless Racing
Member # 82154
bellhousing is excellent, with the following mods:
- pass. side flange ground so as to not bind on driveshaft at max travel
- bottom flange ground flat at same height as oil pan to attach skid plate
- drive side has 1/4" plate welded and threaded to attach hydraulic slave cylinder
tranny is good used unit - has never popped out of gear, but has the usual wear on 1st/reverse teeth.
T-case has all the normal dana 18 leaks(rear shims and bottom pan) and some play in the front yoke(less than 1/8")
would prefer pickup only as i will need to seperate and ship seperately due to weight, but if interested i will try to get detailed info. a quick look at ups.com comes in around 250-300(from 01085) plus whatever i need to crate it.
Old 11-15-2006, 11:45 AM   #7 (permalink)
Member # 72816
emailed ya
