Transmission and transfer cases in Va. - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 02-06-2008, 10:23 AM   #1 (permalink)
Member # 83230
I've cleaned up the shop and I've been holding onto some pieces that I'd rather see gone.
1995 2WD 4L60E w/ 184K. It is fine, and I painfully decided to remove it and install a factory 4WD version. It needs nothing. I'm thinking $400, but will entertain offers.
1995 AWD Transfercase from Astrovan w/ 197K. Has viscous coupling and was pulled from another van and replaced with a dedicated low range 241.
I am not aware of any problems with this unit and I used the van for about a year. It was a monster in snow and ice. I would like $200 for this unit, and again, I'll entertain offers.
1993 231 Transfercase with unknown milage. It is the old Cheverolet 5 stud "star" pattern bolt up. I bought it for a Chevy conversion into a Jeep, but never used it. It turns easily and engages readily. I'd like $150
I have a nine incher with new 4:11 gearing, and a new(er) traclok unit. It had begun to make noise, and we disassembled it once to see if there was wear. It looked normal wear, so I began to suspect the clutches. Numerous doses of Ford additive did not reduce the noise that was only apparent when the axle was warmed up. I cannot tell if it was a driveshaft issue, because the rear was removed and replaced with a Sterling last month.
I'd like to get $200 for the whole axle, but will gladly offer inspection of the axle and entertain offers after it's been looked at.
E-mail is as fast as phone calls.
honchonumberone@peoplepc.com or I believe a PM will trigger a heads up to my e-mail.
I am looking for a Dana 60 rear discs to replace my spare Dana 60 with drums and 4:11 gearing. Will work with you.
SAS H3T is offline   Reply With Quote
Old 02-06-2008, 06:22 PM   #2 (permalink)
Member # 83230
Also have a Dana 44 HP housing. I have knuckles for it, as well as radius arms.
It's empty, and I'll be glad to see someone get use of it.
Old 02-12-2008, 07:21 AM   #3 (permalink)
Member # 83230
BTT
I.m looking to unload this stuff.
Old 03-05-2008, 11:10 AM   #4 (permalink)
Member # 83230
These are getting more affordable by the day!!
Right up until they are scrapped. The local prices for scrap are getting very attractive.
Old 03-12-2008, 03:17 PM   #5 (permalink)
Member # 83230
Scrapped. Aluminum bought very good price. I bought beer.
