FS: 96-351w roller motor and 78-c6 trans (So Cal) - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 06-25-2009, 11:36 AM   #1 (permalink)
Member # 42591
Here's a copy of my craigslist ad.
Up for sale is a 1996 351 roller motor. This came out of a F150. Complete.. Comes with all accessories and everything under the hood. We've been running this in our 87 bronco and using the 87's wiring harness. We bought the motor with 72,000 miles on it.. Did a headgasket job on it less then 800 miles ago.
Perfect to swap into a newer bronco as a replacement or to replace your 302...
Only negatives about it are
1) has an exhaust leak. I believe it's a cracked manifold.. However they're not expensive or hard to find
2) Has a rear main seal leak. . However I do have the replacement just haven't pulled the motor out yet..
It is still in the bronco and can be fired up..
It is mated to a 78 4x4 C6 transmission with a Jr. Shift kit installed full rebuilt done 600 miles ago.
Attached to the C6 is a BW 1345. However I believe the fork in the transfercase needs to be replaced.. Hard to shift into 4low
If you buy the motor/trans for $1500 I'll throw in the xfer case for free..
Seperate
Motor setup - 1k obo
Trans setup - $500 obo
Would like to sell as a complete set, but willing to seperate.. Or throw another 1500ish into it and you can have the whole bronco with a SAS sitting on 40" TSL's. Recently smogged tags good till April 2010. Also willing to trade the whole thing for an integra.
Serious buyers only.
01 - F250 7.3L 4x4. CC Shortbed 6" SL on 37" tires
Spectre is offline   Reply With Quote
