2002 LQ9 77k miles/TH350 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 10-06-2009, 11:49 AM   #1 (permalink)
Member # 84593
I have an 02 Escalade LQ9 with 77000 miles, complete motor, has water pump and crank pulley but no other accessories.
Stock intake, oil pan. Also have the stock headers if wanted. FBW Throttlebody.
$800
Also have a TH350 that I recently tore down to change the output shaft to a Novak 23 spline shorty output shaft with the novak adapter for NP/Atlas 6 bolt style. A Jeep Atlas should bolt right up. Replaced a few clutches that were worn and reassembled. Left the valve body out, was going to replace with a TCI Full Manual but never got around to it. The stock VB is yours if you want it. Also has a stock speed torque converter. Order the $60 flywheel from gm parts and it will all work behind this motor.
$300
buy both for $1000.
Located in Reno, NV.
HardcorewannabeXJ is offline   Reply With Quote
Old 10-07-2009, 08:06 AM   #2 (permalink)
Member # 84593
Ttt
Old 10-07-2009, 11:52 AM   #3 (permalink)
Member # 84593
A few more pictures...
Old 10-07-2009, 10:25 PM   #4 (permalink)
lil-bronc's Avatar
Member # 21881
Does the motor come with the harness and ecm?
Any problems with the motor when pulled? Thanks
Just trying to keep up with the Jones'.
Team Ram Rod - 91
KOH 2012
lil-bronc is offline   Reply With Quote
Old 10-08-2009, 08:53 AM   #5 (permalink)
Member # 84593
No harness or ECM, bare motor.
Ran when pulled, came with a 3 month warranty from the junkyard but that's since expired.
Old 10-08-2009, 09:29 AM   #6 (permalink)
MUDYCRAWLER's Avatar
Member # 47029
Is the tranny a K case short shaft?
Can you post a pic or 2 of the top looking down on the Intake,and rear/back of the block, Please.
Need any TSL 38.5/14.5/16.5 in 3/4 condition? or?
Big Red Motorsports Ultra4 Car #775 Battle Born Team
Thank You to my Sponsors,
Ruff Stuff
AxleTech
Stazworks
Griffin Thermal
Poly Performance
A1 Upholstery
https://www.facebook.com/pages/Big-R...02719553078897
A-1 UPHOLSTERY 775-577-0600
MUDYCRAWLER is offline   Reply With Quote
Old 10-08-2009, 09:31 AM   #7 (permalink)
Member # 47029
estamate for the cost of ECM and harness? have you looked intoit?
Ruff Stuff
AxleTech
Stazworks
Griffin Thermal
Poly Performance
A1 Upholstery
Old 10-09-2009, 11:44 PM   #8 (permalink)
Member # 23843
WTF??? You selling it before you build a buggy for it???
Well I got...ecu,cable throttle body and ps/alt bracket for this!!!
ECUs $50-$100
Harness used from the Ls1 board that will still need someone to thin for ya...
about $100-ish
Bump for ya Connect!!!!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote
Old 10-10-2009, 10:20 AM   #9 (permalink)
Member # 47029
Hey Jeromy,
Do you know this guy? (can you get him to respond?)
Do you know the motor?
I was thinking of a 7 wire aftermarket computer just for buggies?
You familiar with it?
Ruff Stuff
AxleTech
Stazworks
Griffin Thermal
Poly Performance
A1 Upholstery
Old 10-12-2009, 10:08 PM   #10 (permalink)
Member # 84593
Hey Jeromy,
The motor is as stated, a 2002 LQ9 out of a Cadillac Escalade. It still is completely stock with the FBW throttle body and truck intake (same as a LQ4)
I was going to get my harness and ECU tuned by Twisted Customs, however I was not going to use their fuel system. A good BRAND NEW custom harness for the motor with a 4 wire hookup and using a stock ECU (reprogramming can run up to a few hundred $$$) is about $700.
Jeremy is going to take a stock harness and send it to jimsperformance.com I believe to get the work done, and ecu programmed. They come highly rated.
Also the TH350 has a Novak Adapters short output shaft 23 spline, the one that is meant to go to a 23 spline NP231.
Jeremy is also going to do the exact same thing I was with his setup, and he has probably put bit more research into the cost.
Old 10-14-2009, 08:33 AM   #11 (permalink)
Member # 84593
Ttt
Old 10-14-2009, 06:02 PM   #12 (permalink)
lil-bronc's Avatar
Member # 21881
Have you heard it run?
Have you checked compression? Thanks.
Team Ram Rod - 91
KOH 2012
Old 10-14-2009, 06:54 PM   #13 (permalink)
Member # 84593
I haven't no, but I'm sure it's as good as the last 4 or 5 motors I have gotten from the same yard. I believe they do run it and compression test it before it leaves.
Old 10-15-2009, 02:04 PM   #14 (permalink)
Member # 84593
btt
Old 10-16-2009, 09:32 AM   #15 (permalink)
Member # 84593
Price drop, $900 and $350!
Old 10-16-2009, 08:55 PM   #16 (permalink)
lil-bronc's Avatar
Member # 21881
where abouts in Reno are you? I will make a trip soon, but I have a friend that lives there.
Team Ram Rod - 91
KOH 2012
Old 10-16-2009, 10:33 PM   #17 (permalink)
Member # 84593
I work in Reno by the airport, but I live in Spanish Springs. Let me know, I'm sure we could work something out.
Old 10-17-2009, 10:01 PM   #18 (permalink)
lil-bronc's Avatar
Member # 21881
Can you me your info please.
Team Ram Rod - 91
KOH 2012
Old 10-19-2009, 03:30 PM   #19 (permalink)
Member # 84593
More pictures of this easy 400 horsepower after exhaust and cpu tune motor!
TH350 with Novak Adapter
Old 10-21-2009, 08:03 AM   #20 (permalink)
Member # 84593
Ttt
Old 10-23-2009, 08:14 AM   #21 (permalink)
Member # 84593
ttt
Old 10-26-2009, 08:05 AM   #22 (permalink)
Member # 84593
Monday Morning!
Old 10-27-2009, 08:52 AM   #23 (permalink)
Member # 84593
Btt
Old 10-29-2009, 09:27 AM   #24 (permalink)
Member # 84593
ttt
Old 11-02-2009, 08:56 AM   #25 (permalink)
Member # 84593
Btt
