Vertical Limits
Member # 26443
Ford married 205 in KS or Cali for KOH
Married ford 205. 31 spline input, 32 spline outputs with the fixed rear yoke. This is the case you need to get drivers drop if you can't afford an atlas. I have 32 spline inputs for it brand new in the box with bearings if you want to put it on the back of a 400 as well. I can do that for another $125
Just the stock Ford 205 is $150, neg 32 spline Ford 205 for use with a 400, $275 Twin sticked adds another $100 Kelly 913.731.3040 I'll be on the lakebed all week, so if you're in the KOH area and need a case, get it locked down now and I'll haul it out for a case of beer edit: sub
Kelly Kaiser Vertical Limits Inc 913.731.3040 Atomic Fabworks (my new full time shop) www.atomicfabworks.com 913.839.8450 Your ORI struts, Solid and Rod End Supply dealer! team Nasty co dog. FINISHED KOH Last edited by blacksheep10; 01-31-2010 at 08:15 PM. |
Vertical Limits
Member # 26443
top
Kelly Kaiser Vertical Limits Inc 913.731.3040 Atomic Fabworks (my new full time shop) www.atomicfabworks.com 913.839.8450 Your ORI struts, Solid and Rod End Supply dealer! team Nasty co dog. FINISHED KOH |
Member # 123788
205
You still have this??
'96 F-250 ''Short bed'', Detroit Rear, Welded chromo 60 front, 460 & C6 with BW 1356; '05 Dodge 3500 6x6, Sweet 5.9 with South Bend dual-disc clutch, 6 speed, stock drivetrain :D |
Vertical Limits
Member # 26443
I have 1 or 2 still I think. This particular one might be gone, but I can put together whatever you want. I might still have one with 1410 yokes front and rear, top shaved and everything else ready to go. I'm not sure whether or not I have a 31 spline input left, have to look.
Kelly
Member # 123788
205
What I am hunting is just a stock 205 with a C6 adapter. CHEAP would be best. I will twin stick it myself. Thanks
Vertical Limits
Member # 26443
no c6 adapters to speak of, and you're a ways off from KS. I can't believe you can't find a 205 in the yards around you somewhere if you're just looking for a stocker without anything special. I could probably hunt one down but that's most likely not worth my time if you want cheap.
#7 (permalink) | |
Member # 123788
#8 (permalink) | |
Vertical Limits
Member # 26443
Ill ask my buddy that had several. Going rate up here is 150 for a case no adapter. I can't imagine the adapter being more than 25. Twin sticked adds 50
