Bill Mitchell Merlin 632/800hp (Monster Torque) - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 06-04-2010, 06:55 AM   #1 (permalink)
Member # 91582
I bought this motor a few years back for my competition mud racer. I'm not a pro or anything like that just had an 84 Chevy and wanted big power and that’s what I got with this power plant. Really way more than I needed for the truck I had, Spent most of the time repairing drive lines. Motor doesn’t have much time on it at all, Runs great still in truck so I can run it for you. I had a huge rear mounted radiator so motor has never been hot. It has a MSD off road 6al ignition with rev chip and I had it set about 800 rpm below red line to keep from spiking past the chip in a part failure situation. The only down fall is that the motor was in a mud racer so its stained up from mud if you were going to put it in a car or something you would want to re-polish it. The motor has a March billet pulley kit on it that would with it as well as a 140 amp gm alternator. I’m leaving everything on the motor except for the steering pump, Air cleaner to oil pan. This motor is over 20k the way it sets. All this one needs is a little polishing and you’ll be king of the street. Below I’ll attach the info from Bill Mitchell on the engine specs. If you have any questions let me know and I’ll do my best to get them answered for you. YOU CAN HEAR THE MOTOR RUN. Trucks has a broken front knuckle and is in part out mode but motor is still in truck and in run mode.
This is the street 632. Low Compression pump Gas
Limited Edition Big Block Chevrolet Street Engines
It's hard to beat this “Limited Edition” Hardcore 632 engine for all-out power, tree stump-pulling torque and total reliability. It delivers 800 dyno-tested horsepower on pump gas and everything is covered by a 2-year, 24,000-mile limited warranty.
What's more, reliability is clearly one of the important features of the hot “Limited Edition” engines from Bill Mitchell Hardcore Racing Products. Each engine is individually assembled to racing tolerances by skilled technicians, carefully broken in, then dyno-tested and certified to meet or exceed published performance data. Roller cams and Hardcore blueprinted 4500 series carburetors help give these engines a whopping 775 foot-pounds of torque. This is definitely the “king of the hill” when it comes to powerful, yet reliable street engines. We urge you to compare this to any other “crate engine” on the market today. It stands alone!
Block: World Merlin III cast iron billet caps
Crankshaft: Callies 4340
Balancer: ATI
Connecting Rods: Eagle H-beam 4340
Pistons: Mahle coated/Manley
Piston Rings: Total Seal
Compression: 10.5:1
Bore/Stroke: 632 c.i.d. = 4.600" x 4.750"
Bearings: Clevite H-bearings
Camshaft: Hardcore solid roller lifter
Timing Chain: Hardcore double roller
Cylinder Heads: World Merlin (aluminum)
Valves: Manley Severe Duty® (2.300" intake, 1.880" exhaust)
Valve Springs: Hardcore
Retainers: Manley
Valve Locks: Manley
Valve Seals: Hardcore
Rocker Arm Studs: Manley
Pushrods: Hardcore 4340 1 pc.
Pushrod Guide Plates: Hardcore
Rocker Arms: Scorpion aluminum rollers
Oil Pan: Moroso
Oil Pump: Melling/Federal Mogul
Assembly Components: Stainless hardware
Intake Manifold: Merlin-X single plane
Carburetor: Hardcore 1050 cfm (4500 type)
Distributor: HEI
Fuel: Pump gas
BIG-RED is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 06:56 AM   #2 (permalink)
Member # 91582
$10,500.
Old 06-04-2010, 06:58 AM   #3 (permalink)
Member # 91582
Building a new KOH Racer Got to move this motor
Old 06-07-2010, 07:04 AM   #4 (permalink)
Member # 91582
Bump
Old 06-07-2010, 05:56 PM   #5 (permalink)
redneckryder84's Avatar
Member # 57010
still got the radiator and fan setup? how about the SCS box?
redneckryder84 is offline   Reply With Quote Quick reply to this message
Old 06-08-2010, 08:40 AM   #6 (permalink)
Member # 91582
I do. but going to leave it all together for now. Wanting to put a smaller motor in it and just make a good trail truck out of it.
Old 06-08-2010, 08:42 AM   #7 (permalink)
Member # 91582
Were going wheeling up at yellow creek next weekend.
Old 06-11-2010, 08:20 AM   #8 (permalink)
Member # 91582
bump
Old 06-14-2010, 10:13 PM   #9 (permalink)
Member # 91582
bump
Old 06-22-2010, 08:58 AM   #10 (permalink)
Member # 91582
Bump..
Old 12-01-2010, 08:17 PM   #11 (permalink)
Member # 91582
Bump . .
Old 12-01-2010, 08:42 PM   #12 (permalink)
Member # 77901
Put that bitch in your KOH car ......
.....seriously though, do it...
I will take your advice into cooperation.
JHALL is offline   Reply With Quote Quick reply to this message
Old 12-01-2010, 10:31 PM   #13 (permalink)
bigal1's Avatar
Member # 119174
where you at in eastern ohio?
bigal1 is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 08:54 AM   #14 (permalink)
Member # 91582
Located in East Richland, OH
Got a supercharged LS-2 for the KOH Racer.. !! Half the weight. and lots smaller and a hell of alot better on fuel. I'd need a 100gal cell for the 632. Sure would be fun though..
Old 12-05-2010, 03:16 PM   #15 (permalink)
Member # 91582
bump
Old 12-08-2010, 06:23 PM   #16 (permalink)
Member # 91582
May Consider LS motor as partial trade or trade depending.
Old 12-16-2010, 10:40 AM   #17 (permalink)
Member # 91582
Christmas Sale !!! lol
$9,500...
Old 01-05-2011, 10:38 AM   #18 (permalink)
Member # 91582
bump
Old 02-21-2011, 09:34 AM   #19 (permalink)
Member # 91582
motor
bump
Old 02-21-2011, 03:40 PM   #20 (permalink)
Member # 168685
Bump
rockdevil68 is offline   Reply With Quote Quick reply to this message
Old 02-23-2011, 07:01 PM   #21 (permalink)
Member # 91582
632
bump
Old 02-24-2011, 01:25 PM   #22 (permalink)
Member # 184157
motor
would you be interested in a mild 396 forged pistons dimple rods forged crack rectangle port heads or a built 406 small block aluminum head all forged internal motor
gants4268 is offline   Reply With Quote Quick reply to this message
Old 02-25-2011, 09:10 PM   #23 (permalink)
Member # 91582
632
Not at this time. thanks
Old 02-28-2011, 09:40 PM   #24 (permalink)
Member # 91582
632
bump
Old 03-06-2011, 05:45 AM   #25 (permalink)
Member # 169597
Consider the 632 sold, which Saturday works best for the pickup, 19 or 26 March.
Dale
Dale1234 is offline   Reply With Quote Quick reply to this message
