700R4-Fresh rebuild- Never used-$800 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 06-13-2010, 04:19 PM   #1 (permalink)
Member # 111000
700R4-Never Used-Price Reduced-$700-Can Deliver During Holiday Travels- See Post
I have a professionally rebuilt 700r4- "K" case (4x4). Built by Mad Dog Transmissions. This transmission was built to withstand 500 HP- High performance clutches, drum, and torque converter. Tranny comes with dipstick tube and TV cable. I paid $1100 for this tranny but now my project is going in a different direction. It has just been sitting on my garage floor, never even mounted.
Possible trades for: 16" coilovers, 39-42" tires for 16.5 rim, or tube bender and dies
Info from website: Maddogtransmissions.com
Features:
Level 2 700R4
Rated up to 500HP
All Mad Dog Transmissions are completely rebuilt and come with a Master Overhaul Kit which includes:
-all new lip seals
-all new gaskets
-all new Teflon rings
-new filter
-all new steels
-all new bushings
-all new Raybestos clutch discs
-all new sprags
This Level 2 transmission comes with an Mad Dog Reprogramming update kit, Mad Dog shift kit, and Raybestos 9 clutches (replaces factory 5 clutches in the 3-4 drum) the 9 clutch pack also has specialized heat treated steels that withstand much more heat, all Raybestos high temp high energy clutches through out the rest of the unit, all new steels, band, bushings, and rings. A 500 boost valve, 10 vane pump rotor. The reason we run a 10 vane pump rotor and not a 13 vane pump rotor is because the more vanes it has in it weakens the rotor. We also use 4140 hardened pump rings, TEFLON pump bushing, a 29 element sprag, Sonnax wide-open throttle valve, over-sized hardened sun gear shell (which is three times thicker than factory) hardened input shaft and drum, 4 pinion planetary gear (which has also been cold-freezed to withstand big horsepower and torque), high-temp Pro-series, Kevlar band and a Billet servo.
Last edited by Hooker47; 01-03-2011 at 06:42 AM. Reason: 700R4-Never Used-Price Reduced-$700-Can Deliver During Holiday Travels- See Post
Hooker47 is offline   Reply With Quote Quick reply to this message
Old 06-13-2010, 08:07 PM   #2 (permalink)
Member # 14640
Do you have purchase papers (receipts) for this? Is the warranty transferable? Does this include the cast aluminum flywheel cover? What stall is the torque convertor?
Thanks.
Monkeyplasm is offline   Reply With Quote Quick reply to this message
Old 06-14-2010, 06:52 AM   #3 (permalink)
Member # 111000
PM sent to Monkeyplasm
Old 06-15-2010, 04:38 PM   #4 (permalink)
Member # 111000
ttt
Old 12-02-2010, 08:18 AM   #5 (permalink)
Member # 111000
btt
Old 12-06-2010, 06:41 PM   #6 (permalink)
Member # 111000
btt
Old 12-07-2010, 10:39 AM   #7 (permalink)
Member # 52790
PM Sent.
Tri-State 4x4
Total Karnage
xeon is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 07:35 AM   #8 (permalink)
Member # 111000
PM's returned
Old 12-13-2010, 08:56 PM   #9 (permalink)
71Stryker's Avatar
Member # 169993
What spline is the output shaft on the 700R4? What is needed to bolt it up to an Atlas 4 speed...or do you have an adapter available? Also, are you willing to ship?
thanks!
71Stryker is offline   Reply With Quote Quick reply to this message
Old 12-17-2010, 05:08 AM   #10 (permalink)
Member # 111000
Post updated
Old 01-03-2011, 06:43 AM   #11 (permalink)
Member # 111000
spend that Christmas money!!!!!
Old 01-07-2011, 09:07 AM   #12 (permalink)
Member # 111000
back to the top
Old 01-15-2011, 06:54 PM   #13 (permalink)
Member # 111000
to the tpp
Old 02-25-2014, 04:58 AM   #14 (permalink)
Member # 153528
do you still have this tranny? If you do what stall torque convertor does it come with? I need it shipped to Miami FL. 33142
tfphill is offline   Reply With Quote Quick reply to this message
