NP203/205 WMS Doubler Driver Drop - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Classifieds > Engines/Trannys/T-Cases For Sale
Old 12-28-2010, 07:29 PM   #1 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
Complete NP203/205 doubler setup with a Wagoner Machine Shop steel adapter for a driver drop Ford NP205 w/ 1410 yokes. Setup came from behind a 700R4 and includes the figure 8 to round 4 adapter (no output shaft mod needed) and 27 spline input shaft. Both cases included w/ Ford already converted for twin stick, will include shifter handles but no knobs, linkages or boots. Setup was 2 sticks on left, 1 on right. 205 is will require mods to be clockable as shifter mount is integrated to adapter. Both cases were rebuilt and painted hammered gray prior to installation. Ran behind a show V8 Jeep and has no hardcore runs on it, just a few hundred miles of pavement in 2 high.
Willing to ship on your dime. I drive to DFW and OKC semi-regularly. Willing to deliver within a few hundred miles for gas + a little extra. Willing to separate.
$1000 OBO for everything listed (everything in the photos). Located in Tulsa, OK.
I also have a stock NP205 w/o a rebuild or twin stick that I will swap in place for less.
1998 Dodge Ram 2500 Twins: 1 black, 1 white...
"The only thing necessary for the triumph of evil is for good men to do nothing." Ooh Rah!
USMC 2003-2009
swirvin21 is offline   Reply With Quote Quick reply to this message
Old 12-29-2010, 07:24 PM   #2 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
Had a few people ask about separate pricing.
Everything w/ stock NP205: $750
Everything w/o a NP205: $650
EDIT:
This should work with a passenger drop Chevy NP205 round pattern if you do the big bearing swap to a Ford 31 spline input shaft. Shifter setup remains the same.
USMC 2003-2009
Old 12-30-2010, 03:21 PM   #3 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
Ttt
USMC 2003-2009
Old 12-30-2010, 07:02 PM   #4 (permalink)
Member # 156866
trade for a chevy dana 60
jrmellies is offline   Reply With Quote Quick reply to this message
Old 12-31-2010, 12:26 PM   #5 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
I sent you a PM. I may be interested, need to know the specs first. Where are you located?
USMC 2003-2009
Old 01-01-2011, 08:20 PM   #6 (permalink)
Member # 145810
doubler
Can you get a quote for shipping to 89434, i have a loading dock...
Thanks
james
ELS-FACTOR is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 07:47 AM   #7 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
Some simple quotes come out to around $300, but are you planning on going to KOH? I'm pretty sure I could get this on someone's trailer to KOH for pretty cheap since it's relatively small. I can also take off the 205 which would drop the weight down to around 125 pounds from around 300.
USMC 2003-2009
Old 01-02-2011, 10:14 AM   #8 (permalink)
Member # 145810
Look!!!!!
Check your pm's!!!!!
Old 01-02-2011, 11:23 AM   #9 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
PM replied.
I will see about finding a ride for it to KOH and post up.
USMC 2003-2009
Old 01-06-2011, 08:06 AM   #10 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
PM sent regarding shipping to KOH. Found a ride for $50. Sale Pending...
Pics you requested with measurements
Forward yoke, same as rear. measurements seem to match 1410s
Length w/ 700R4 adapter, measured from trans mount to center of cap in rear yoke. Drops closer to 21" without 700R4 adapter
Forward 700R4 mount angle, not quite flat top like I had though. Cocked to the driver side around 10*, can put an angle gauge on to check if need be.
USMC 2003-2009
Old 01-07-2011, 09:19 AM   #11 (permalink)
Embrace the Suck
swirvin21's Avatar
Member # 116370
Payment received! Thanks James! I will start putting together a small pallet and rough crate to protect it.
USMC 2003-2009
