you pinko commie fag
Member # 67732
Sbc performance parts, 383, aluminum heads, etc...
3500 STALL BOSS HOG CONVERTER W/DUAL ANTI-BALOONING PLATES-300
th350 tranny built to handle 550 hp motor- $750 ALL THE ENGINE PARTS ARE FOR AN EXTERNALLY BALANCED 383 FULL ROLLER MOTOR. The engine- $3,000 FOR THE WHOLE THING... 383 c.i. 11.5:1 compression, externally balanced Intake- Professional Products Hurricane single plane, polished aluminum- $125 Heads-aluminum Canfields 195c.c., 2.1 intake valve, 1.6 exhaust valve, 76 c.c. chambers- ported polished and gasket matched, come with rev severe duty valves and 600 lift springs, for solid roller cam setup with 581/597 lift. -$1500 Crower roller rockers 1.5 ratio- $300 keith black hypereutectic pistons and scat 4340 forged I beam Rods 5.7- $300 Crank- scat 9000 lightweight stroker crank $300 Pushrods- renegade racing standard length- $50 Melling high volume oil pump- $25 Crane roller lifters- $200 Fluidampener harmonic balancer- $200 Howards Cam, custom ground for 383 in a 79 camaro with a manual tranny- 0.581 int. / 0.597 exh 108 lobe center 36 degree overlap Int duration 248.0 Exh duration 256.0 -$150 cloyes polished aluminum timing cover-$75 double roller timing chain- $25 fabricated aluminum valve covers, tall to clear stud girdle- $175 rev kit to eliminate valve float- $175 renegade racing 7 qt oil pan-$75 Last edited by Honky Lips; 02-24-2011 at 06:26 AM. |
