Mini Hägglund - Page 14 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Expedition Vehicles
Old 08-03-2012, 09:37 PM   #326 (permalink)
Member # 104383
Dang, now I have to go back about 8 pages since I visited last. Lots of things have changed and I want to see how you did some of them.
WILLD420 is offline   Reply With Quote
Old 08-05-2012, 02:19 AM   #327 (permalink)
Member # 181746
Damn, i just don`t have time to work on the Hägglund if i continue buying machinery:
I'd rather die trying to live, than live trying not to die.
Steinbruchsoldat is offline   Reply With Quote
Old 08-05-2012, 08:50 AM   #328 (permalink)
Elwenil's Avatar
Member # 41063
Lol, I don't think I would blame you for buying more equipment. Tools and equipment are great to have and can make fabrication much easier. The problem is when you run out of room to work because of all the equipment taking up space, lol.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s
Elwenil is online now   Reply With Quote
Old 08-05-2012, 10:30 AM   #329 (permalink)
Member # 181746
This should be the last big machine that`s going in the shop. I should be able to place it without loosing to much space...
Made the front driveshaft today:
Also made a cover for the belt sander because it kept shooting sparks in my face:
Old 08-06-2012, 08:27 PM   #330 (permalink)
Member # 215352
is this a repost?
Extreme Hagglunds - Track Building - YouTube
ringding is offline   Reply With Quote
Old 08-15-2012, 01:24 PM   #331 (permalink)
Member # 181746
Yes it is...
Reconnected the chassis to the frame today. Front:
Rear:
Both saws at work:
Motor-mount:
Then i started with the new seat mount. The seat is offset to the left now...
First mockup:
"Leg room":
I can even hang out my arm:
I`m going to pick up my new mill tomorrow, really looking forward to it...
Btw., i started a facebook page, would be great if you guys could give it some likes: http://www.facebook.com/Steinez
Old 08-15-2012, 09:11 PM   #332 (permalink)
Member # 37724
Congratulations on all the news tool. The belt grinder you made looks awesome. Are you planning on keeping both the power hack saw and the horizontal band saw?
I can't wait for the first test drive video. I think you said earlier that it might be a while though.
el bob is offline   Reply With Quote
Old 08-16-2012, 06:31 AM   #333 (permalink)
Member # 150595
Sorry, Face Book is gay.
More of the build, less on the gay.
Nat
Nat_sters Haul All [url]http://www.pirate4x4.com/forum/showthread.php?t=1004576[/url]
nat_ster is offline   Reply With Quote
Old 08-16-2012, 12:58 PM   #334 (permalink)
Member # 181746
Yes i do. The bandsaw can be converted into a vertical one in about 30secs. I use it mostly to cut the small parts and the power hack saw for the big things. It can cut pieces up to 8" wide...
Yes, it`ll take a while because i need to finish both cars before i can test drive it. Well, not completely finish, but with tracks and the articulated joint and all that stuff...
First i finished the seat mount today:
Then i started making some room for the mill. There`s a before and after pic each:
Then i cleaned all my new tools and stuff from the anti corrosion oil:
Old 08-16-2012, 12:59 PM   #335 (permalink)
Member # 181746
After that i picked up my "new" mill. Loading it on the trailer:
Arrived at home:
Unloading:
Getting it through the house:
At it`s new place:
Old 08-17-2012, 11:24 AM   #336 (permalink)
Member # 181746
Put the mill at it`s final place:
Added a light:
And built a dro for the x-axis:
Also got this angle block and machined the edges:
Old 08-17-2012, 11:29 AM   #337 (permalink)
Member # 122916
That is a BADASS angle block
1949 F5 '49 Ford truck build
ZukiDuke build The Suzuki Duke
xj9140 is offline   Reply With Quote
Old 08-17-2012, 08:19 PM   #338 (permalink)
Member # 108445
What does that top bit do {on the horizontal mill}?
rocket flier is offline   Reply With Quote
Old 08-17-2012, 11:01 PM   #339 (permalink)
Member # 181746
What top bit? The long thing on top can be pulled out to support a big mill:
Old 08-18-2012, 06:23 PM   #340 (permalink)
Member # 108445
Ah! Gotcha.
Old 08-19-2012, 12:20 PM   #341 (permalink)
Member # 181746
But its not needed, I'm going to use it to build a vertical milling head for it...
Old 08-21-2012, 07:37 PM   #342 (permalink)
Member # 143405
? Change your horizontal mill to a vertical? Been looking for pics of a similar setup but I haven't found anything yet.
ruffryder is offline   Reply With Quote
Old 08-24-2012, 04:11 PM   #343 (permalink)
Member # 181746
I`ll not change it to a vertical mill, i`m going to add a vertical milling head. So i can be milling vertical and horizontal. I`ve never seen pictures of it done the way i`m going to build it...
Started building the articulated joint today. I`m going to build this first before i place the radiator, exhaust and stuff...
The bearing for the left-right-motion will be made from a wheel hub. First i trimmed down the brake drum:
Was able to remove a broken bolt with my mill:
To determine the lenght of the joint i built a wooden template. Picture shows the max. 34° steering and the max. 34° vertical separation: .
Old 08-25-2012, 08:04 AM   #344 (permalink)
Member # 37724
I don't always understand what you are doing, but I look forward to your posts each day. Very cool projects and thanks for sharing.
Old 08-26-2012, 09:00 AM   #345 (permalink)
Member # 181746
First i improved my notcher:
Then i started building the articulated joint...
Further mockup, could work along those lines:
Old 08-26-2012, 08:59 PM   #346 (permalink)
Member # 86724
Tie rod ends for mockup or is that the final part?
rod ends would probably be stronger, but I can't argue against tie rods for cheapness and availability.
ko derf
87manche is offline   Reply With Quote
Old 08-26-2012, 10:10 PM   #347 (permalink)
Member # 181746
Just for mockup. But i think i'll use another concept if i figure out how to build a rotational joint...
Old 08-27-2012, 06:21 AM   #348 (permalink)
Electric Mayhem
irab88's Avatar
Member # 182820
would a type of 4-link setup work? just thought of the rear car as sort of a rear axle. just add in another pivot for any missing degree of freedom
--Ian
93 yota pickup, 4 cylinders of pure mediocrity...
irab88 is offline   Reply With Quote
Old 08-27-2012, 01:36 PM   #349 (permalink)
Member # 181746
This is what i thought first too, but i came up with the idea of a big thrust bearing instead:
Old 08-30-2012, 11:41 AM   #350 (permalink)
Member # 181746
Not much to show, just lathework to get the parts for the rotational joint ready:
Also bought about 400lbs of steel:
