#76 (permalink) |
Member # 119827
here is what i would do;
i would not do the filler pieces of flat stock and i dont think the rubber sleeves will last long if they rub against the bolts ...i would cut rings that weld onto the outside of the cross-tubings replace the nuts with custom turned "spikes" (maybe ~1" stock ...with a nice smooth bullet nose) that are treated to screw over the bolts. maybe run even larger (hardened) washers to avoid that the spikes fold over. the pointy spikes should fairly well "self-center" into the driver spocket (just dont make them too tall or you may run into misalignement problems as you pointed out in the side drawing) ... the metal to metal contact may even work-hardens itself some ...
"Steels gonna be the death of me" ... Gangstergrass Last edited by RoosterBooster; 02-20-2012 at 05:38 PM. |
#77 (permalink) |
Member # 104383
You could try building internal drive teeth that will be held on with the bolt.
I don't have a drawing program, but I'm thinking small square tubing in short lengths that will fit between your drive teeth. Then put a short piece of angle on top to give the tooth a pointed top. If you angle cut the tubing, you can make it ramp from the point down to the track. Then all you would need is to put your guide plates on the ends of the tubes. This would do 2 things. It would strengthen your drive tubes, and provide a positive stop so your drive teeth could not go out the end of the sprocket. The small lengths of tubing, I would drill them all the way through and try to get your bolt to go through both sides to strengthen the bolt and spread the drive forces into a shear load rather than a bending load on your bolt. |
#78 (permalink) |
Member # 14423
Probably a little late, but check this out:
Here in Florida, they used to build fully tracked swamp buggies. Most used conveyor belt material / bolts / angle or channel iron and car tires for the bogies. I hunted for some pics but non so far showed the tracks very well. I did find this and it seems like a good idea especially in a lower torque scenario. Looks like it was a solid rubber forklift tire / wheel that was drilled and cut to make it a drive sprocket. Seems interesting. |
#79 (permalink) | |
Member # 86724
enjoy ghetto fabulous spikes.
ko derf |
#80 (permalink) | ||||
Member # 181746
![]() Quote:
![]() Made a prototype of the track assembly today. Everything works perfectly, exactly like i thought: ![]() ![]() The second track connection is just improvised, but it already works perfectly. I even got a video if you guys want to see it... Of course i had to take a seat: ![]() ![]() I still have to design a (easy to make) centering device for the drive sprocket, any ideas?
I'd rather die trying to live, than live trying not to die. |
#84 (permalink) |
Banned
Member # 41063
I think I'd be more tempted to torch the lower half of the sides off, mount drive sprockets to the hubs, build a suspension setup for some road wheels and run that as is.
That or copy what the Russian's are doing: METELICA.flv - YouTube
#85 (permalink) |
Banned
Member # 41063
Never searched for any of this stuff before but YouTube seems to be full of little projects like this.
Mini Tank Test Drive - YouTube Extreme Hagglunds - Track Building - YouTube tracked pocket bike - YouTube tracked offroad vehicle - YouTube Bandvagn 2.3 D - YouTube |
#86 (permalink) |
Member # 181746
Yeah i know. Most of them use some kind of sprockets (if not friction driven) and guides that are similar to my idea...
#87 (permalink) |
Banned
Member # 41063
I think more importantly, most of the larger and heavier vehicles seem to use some sort of crossbar on the track for the sprockets to grip. I fear that as soon as you get your vehicle on a hard pull, it's just going to start slipping the sprocket and bending the bolts.
#88 (permalink) |
Member # 181746
That`s something that needs to be tried. I think no one can say it works or not...
But i think i`ll add some bars to the outside to increase traction, they should help stabilize the bolts too. And if it doesn`t work, i`ll just build some snowcat tracks...
#89 (permalink) |
Member # 181746
Worked on the shop a bit today:
Before: ![]() During: ![]() ![]() ![]() ![]() ![]() ![]() ![]() Finished: ![]() ![]() It`s nice to have some daylight in the shop...
#90 (permalink) |
Member # 181746
Got the donor car today:
![]() ![]() The battery was completely dead, so we put in another one. It turned over on the first try and ran fine... ![]() We drove a few feet and started parting it out: ![]() ![]() ![]() After two hours of work: ![]() ![]()
#91 (permalink) |
Member # 181746
Built some track-assembly dummies to get an idea of the size. We can place all the parts where they`re supposed to go, so we can see easily if there`s enough room or not:
![]() The little one had to check things out: ![]() This is about where i`ll sit: ![]()
#92 (permalink) |
Member # 181746
Placed some stuff today, this is going to be tight:
![]() ![]() This is about half of the wiring loom. That`s insane... :wow1:
#93 (permalink) |
In the garage
Member # 41068
You look like Sheldon from the television show "Big Bang Theory".
Tow rig build: 1997 F350, Powerstroke, 4wd conversion Crawler build: 1990 Ford Ranger Truggy Daily driver build: 1965 Chevy Last edited by jtr; 03-13-2012 at 08:04 PM. Reason: spelling |
#95 (permalink) |
plasma dust huffer
this could be awesome! keep up the work
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
#96 (permalink) |
Member # 181746
Removed the engine today. Was a pain in the ass...
![]() ![]() Looks like it`ll fit, i`m really happy about that... ![]() ![]()
#97 (permalink) |
Member # 88513
are you going to use the justy transmission? those things are know to be incredibly weak even with the stock power levels, manual or automatic. Some good info http://www.dustysjustys.com/home.htm
other than that its looking good and cant wait to see more progress. |
#98 (permalink) |
Member # 181746
Here are a few more pictures from removing the engine:
![]() ![]() ![]() Also was able to have a look at a real Hägglund yesterday:
#99 (permalink) | |
Member # 181746
#100 (permalink) |
Member # 181746
Got a lot of steel tubes almost for free:
![]() ![]() About 20 shorter pieces are still in my van.... Also bought a saw, to handle all that stuff:
