Mini Hägglund - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Expedition Vehicles
Old 03-18-2012, 07:15 PM   #101 (permalink)
Member # 88513
sounds good then, good luck with your project.
jeeper90 is offline   Reply With Quote
Old 03-19-2012, 03:12 PM   #102 (permalink)
Member # 181746
So, we parked the Justy for some good access to the axles:
I'd rather die trying to live, than live trying not to die.
Steinbruchsoldat is online now   Reply With Quote
Old 03-20-2012, 09:05 AM   #103 (permalink)
surpip's Avatar
Member # 22748
Awesome, I had no idea that redneck had made to Germany. Love it.
R.I.P. DOZER
R.I.P. Jason
GREAT SPIRITS HAVE ALWAYS ENCOUNTERED VIOLENT OPPOSITION FROM MEDIOCRE MINDS
-ALBERT EINSTEIN-
#472tellico rally
xtrm-s10 is a bad hauler dont let him haul your stuff
Buy my mega cab
KJ6IYH
surpip is offline   Reply With Quote
Old 03-20-2012, 09:07 AM   #104 (permalink)
Member # 86724
his neighbors must love him already. just moved in and trashing up the place.
ko derf
87manche is offline   Reply With Quote
Old 03-20-2012, 01:39 PM   #105 (permalink)
Member # 181746
Well, it`s just the third car i`m parting out there. And i was already there when most of my neighbors moved in...
Picked up the saw today:
After a bit cleaning, fresh oil and dialing in it runs like on it`s first day:
Bought it for about $200, the seller thought it`d be broken...
Old 03-22-2012, 01:44 PM   #106 (permalink)
Member # 181746
Finished parting out the Justy yesterday. Here`s a pic of removing the rear axle:
Made a roller stand (?) for my saw:
Also a jack stand for some welding practice:
Will pick up the steel tomorrow, so i`m going to have the first track assembly ready by Saturday...
Old 03-23-2012, 12:47 PM   #107 (permalink)
Member # 181746
Couldn`t get the steel today, maybe tomorrow if i`m lucky...
We started making a hole in the wall for ("thing that evacuates welding fumes" how`s this called?):
Also made a stack for shorter pieces of steel:
What i need now is an idea what to use for the turning connection between both cars. There`s the up and down and the left and right movement between both cars. I already designed the joint for that. Now i need a joint that is able to turn around itself and fitting a driveshaft through it. Something like the "thing" that`s between the upper and lower part of an excavator and allows it to turn...
Old 03-23-2012, 01:34 PM   #108 (permalink)
Member # 122916
Exhaust vent.
Thanks for sharing amigo.
xj9140 is offline   Reply With Quote
Old 03-24-2012, 10:55 AM   #109 (permalink)
Member # 181746
Originally Posted by xj9140 View Post
Exhaust vent.
Thanks but i think the word i was looking for is fume exhauster:
Also ran a air hose down in my shop:
I didn`t get the steel today, so i got the axles ready. I`m going to use the rear axle in the front car and the front axle in the rear car. The drive sprocket fit`s perfect:
I`m going to finish the front car first and make a simple skid steer mock up with the parking brake, so i`m able to test drive the front car itself...
I also decided to get a small trailer to transport the front car. The rear car will go in my van...
Old 03-25-2012, 09:38 AM   #110 (permalink)
Member # 33536
nice fab work, always cool to see projects from other countries.
try fume extractor:
http://www.mist-dust-collection.com/...ms_Flexair.htm
85blue4runner is offline   Reply With Quote
Old 03-25-2012, 01:52 PM   #111 (permalink)
Member # 181746
Came up with a new design for the joint between both cars. It`s based on the real one and should be a lot better than my old design:
Old 03-25-2012, 03:28 PM   #112 (permalink)
Back Woods's Avatar
Member # 74825
All the license plates over the have UL on them?
Back Woods is offline   Reply With Quote
Old 03-25-2012, 10:30 PM   #113 (permalink)
Member # 181746
The first letters are different, depending on where you live. I live in Ulm, so it's UL. If you live in Stuttgart it's S and so on...
The other characters are based on chance(?)...
Old 03-26-2012, 12:46 PM   #114 (permalink)
Member # 181746
Finally got my steel today:
And started over:
Unfortunately it warped while welding, so i have to cut it off and redo it tomorrow... :coffee:
Old 03-27-2012, 12:07 PM   #115 (permalink)
Member # 181746
Redid the part from yesterday:
Then i started with the second one:
Both finished:
Old 03-28-2012, 01:15 PM   #116 (permalink)
Member # 181746
Figured out the final dimensions and engine position today. Also shortened the drive shafts:
Then i started with the frame:
And started machining the second drive sprocket:
Old 03-29-2012, 11:57 AM   #117 (permalink)
Member # 181746
Big change of plans today:
Engine/Drivetrain:
I wan`t happy with the engine position all the time. The center of gravity is way to much up front, the aperture angle is incredible bad for a tracked vehicle. And the drivers view is really obstructed by the big engine...
So i decided to put the engine all the way back in the front car and built a chain setup to the drive sprockets. I think this is a lot better...
Suspension:
It`s not a really good idea to built a vehicle without any type of suspension. The real Hägglund uses two leaf springs to hold the track assemblies and the chassis together:
Not much to say, i`ll do it the same way...
Old 03-30-2012, 11:59 AM   #118 (permalink)
Member # 181746
Almost finished one track assembly today:
Just had to take a seat....
So much better than before...
Old 03-31-2012, 12:29 PM   #119 (permalink)
Member # 181746
First i finished both track assemblies today:
Then i started with the main chassis beam:
This is how it`ll be mounted:
Placed all the stuff. Space is tight, but everything will fit...
Old 04-01-2012, 07:35 AM   #120 (permalink)
Member # 181746
Here`s another pic of the track assembly:
Also started with the second track:
Old 04-01-2012, 08:10 PM   #121 (permalink)
Member # 86724
starting to look like something there.
It looks like the motor is sitting on the factory subframe. Are you planning on reusing that or building a custom piece to support the motor and radiator? Worried about cooling with the radiator in the back?
ko derf
Old 04-02-2012, 11:31 AM   #122 (permalink)
Member # 181746
Yes, i`m reusing the factory subframe. Saves me a lot of time making the lower engine/tranny mounts. I just need to tie it into my frame and built the two upper engine mounts...
I don`t think there will be cooling issues, the engine shoiuldn`t be under heavy load...
Old 04-03-2012, 01:02 PM   #123 (permalink)
Member # 181746
Tied the subframe into the main chassis beam today:
Still thinking about how i`m going to tie the upper mounts into the frame. Maybe you guys have some suggestions?
Also got the bearings for the cv shafts:
Got the small one painted on sunday:
Old 04-06-2012, 10:10 AM   #124 (permalink)
Member # 181746
We still couldn`t figure out how the articulated joint between both cars works. Because of this we took a ride to a ski resort where i know there`s a Hägglund in use. We looked at it and tried to figure out how it works but we still couldn`t. I looked for the owner and asked him how this think works. He tried to explain it, but couldn`t figure it out himself. So he drove it right over the next ditch, so it would articulate. Then we had a look and finally saw how this works:
Looks like the bearings of the rear joint are some sort of rubber bushings:
But the joint itself takes the most movement, you can see it here:
Kind of hard to figure this out if the car isn`t articulated...
Old 04-07-2012, 12:43 PM   #125 (permalink)
Member # 181746
Started the cage today:
First i made the window frame, to get the exact width:
With this measurement i could start with the cage:
My saw spilled cooling fluid all over the place, so i made this thing:
Almost finished:
Not sure why it looks like crap on those pictures but it`s all square and how it should be...
