I like nacho's
Member # 113687
Just wondering? I read in a magazine about they Aussie challenge. One of the things that caught my eye was that they were using some sort of pump or bilge pump to remove water from the interior of the vehicle. Blows me away! Never woulda thought of it myself. Anyone out there doing this and what kinda pump are you using? Obviously 12v but what brand and where do I get one?
'87 Samurai, BUILT 1.3 with harley carb, Spring over, Lock Rights, 6.5's, OBA, 8k Smitty, on 33's Representing the underdogs ![]() '93 4runner (AKA: The Clean One Owner) Supercharged 3.4 Swap done, E-Locker in the rear, and a straight axle in the future. |
I like nacho's
Member # 113687
Very true, after your out of the water. But during your fording, a pump would be nice to keep the water level down.
Member # 41063
I remember reading about them using those about 10 years ago. I found the the hydraulic winches they used with a PTO pump and an electric back up pump a bit more interesting.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s |
All depends on how much of a problem you have with water coming in as to whether it was worth it to you.
Head down to the local marine shop and just buy a 12V bilge pump. Chances are that they have more experience with such things than your average 4Wheeler.
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
Member # 104383
A good bilge pump will flow about 1000 gal/hour. About as much as a 5/8 water hose at your house. If you leak faster than that, you need to plan accordingly. A pto driven water pump can flow 1000 gal/15 +/- min. There are bigger ones, but you really don't want to go there for this application.
I'd think you would be better off waterproofing as much as possible then go from there. |
No way any 12v bilge pump is going to do a damn thing if you've got water pouring in. As was said, drain plugs are a much better idea. That, or not going in water that's at cab level.
Those brits and aussies do some weird shit though. It seems like most of the comps involve getting stuck and racing with winches...?
In vino veritas 70 turbocharged 351w fastback mustang 73 linked 5.8efi Bronco 99 QCLB 4x4 twin'd cummins on meth. |
#8 (permalink) | |
I like nacho's
Member # 113687
Member # 41063
I've also thought that the bilge pump idea was a bit over the top. Generally you aren't going to be in deep water for long and guaranteed it will drain out quicker though the holes in the floor than a pump will get it out. I might be able to see it if you plan on driving around in flood water or something for long periods but then you better have a full military style fording kit with a pressurized drivetrain.
Member # 5963
ever seen this top gear episode?
http://www.livevideo.com/video/dudew...african-a.aspx they used a rifle to shoot a hole in the floorboard to empty the water. ![]()
2001 Range Rover HSE 4.6 2001 BMW E39 sport package |
