Inverter Calculations - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Expedition Vehicles
Old 07-27-2008, 04:57 PM   #1 (permalink)
Member # 33536
Watts = Volts x Amps, 1000 watts is a kilowatt,
To use the full potential of a 1000 watt inverter (12 VDC to 120VAC), do I need 12VDC and about 1000 watts going in or do I need 10,000 watts going in, at a given amperage.
It doesnt seem that 10k watts would be required as that is over 13hp, but the equation above suggests that is the case... 12 volts is 10% of 120 volts and 120 is 10 times 12...so to make the math work, it seems the wattage would be times 10 also.
Does the 12VDC just get converted to 120VAC and the wattage stays about the same?? The inverter is supposedly 90% efficient.
thanks
85blue4runner is offline   Reply With Quote Quick reply to this message
Old 07-27-2008, 06:11 PM   #2 (permalink)
jasonmt's Avatar
Member # 3236
Ohms Law is your friend, a Watt is a Watt no matter if it is AC or DC at any voltage; 1000 Watts @ 120V AC is going to give you 8.333 Amps @ 120V AC
Assuming that your inverter is ~90% efficient 1000 Watts out is going to be 1100 Watts in so 1100/12 (Watts/Volts)=91.666 Amps @ 12V DC.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 07-27-2008, 07:11 PM   #3 (permalink)
Member # 33536
for some reason, i was not changing the amperage.. that makes sense now thanks.. i knew 10k watts didnt sound right, but i guess it could be mathematically correct if amperage stayed the same...
thanks again..
Old 07-27-2008, 10:46 PM   #4 (permalink)
Member # 75918
Actually a watt is not always a watt when considering AC power. 120VAC is a reference to the RMS voltage. Generally, there's a power correction factor that comes into effect depending on whether the load is resistive or inductive. It's also dependent on how many phases are in use.
When considering an inverter it's generally easier just to look at the volt/amp ratings on the output for peak and continuous load and how that translates to DC input. Most mass-market inverters won't really function continuously at the advertised watt output no matter how one calculates it.
halbritt is offline   Reply With Quote Quick reply to this message
Old 07-28-2008, 05:58 AM   #5 (permalink)
jasonmt's Avatar
Member # 3236
Why make things more complicated when they need not be, the 120V AC being the RMS value rather than peak or average is a given in this application...
Old 07-28-2008, 11:31 AM   #6 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
Honestly, it's easiest and fairly accurate just to use a factor of ten. This will factor in the fact that your batteries are actually operating at 12.2-12.6 volts (assuming you aren't over discharging them), your inverter efficiency, the fact that inverters sometimes output 110 or 115 instead of 120, etc. I haven't had this method fail me yet, especially considering you're a fool not to factor in SOME margin of safety.
So...you need 7 amps AC and you use the factor of 10...that's 7*10 or 70 amps@12vdc. Watts are watts as far as this calculation is really concerned so you can arrive at that number either way. 7*120=840 watts or 70*12=840 watts.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote Quick reply to this message
