Member # 90316
12V and 110V in 4x4 Van
I'm starting with a 2002 E350 V10. It has a Dana 60 4X4 conversion, built in Onan 5500 watt generator but the Inverter and extra batterys were removed. It has roof air. It was a Goverment computer/camera van so I had to practacly gut the inside. It will be a mult use tow rig /adventure camping rig.
I'll run the generator for a 110V hotplate stove, microwave and rooftop AC/heat unit but only want to run the geny for the big stuff when I have too. It uses 1 galon per hour. I will split use between 12v and 110v geny. Do you think one nice 12V batt will be enough for interior lights ,laptop and small DVD TV or do I need two? What size inverter/charger would you use? The RV inverter/ chargers with the built in transfer switch get pricey real fast and I only want to buy what I will use. I also plan a swich to the main engine battery so I can charge it with the Inverter. Is that OK without hurting any of the Ford factory stuff like the computer? Any tips or sugestions on how you would outfit a 4x4 van in any way would be helpfull. Last edited by Stumpalump; 01-25-2009 at 08:40 PM. |
Member # 121833
Have a second deep cycle battery, in addition to the regular starting battery. Get some 12v LEDs for lighting. For your laptop, they make direct 12v to laptop converters... this saves you the trouble of wasting energy with an inverter and then using your stock laptop converter to put back to DC.
Try to get as much to run off 12v as possible, only using inverter when needed. You can run a deep cycle dry without doing damage while a regular car battery will not like that. Also, assuming you did not drain it, you will have a backup starter battery if your factory one fails. As far as charging, just get a high quality 120v to 12v battery charger and have it hardwired in. |
Member # 90316
Gotcha. I think I'll just wire up a whole secondary 12V system for the back and use the geny to charge it. I guess I can just run my regular car battery charger off the 110V. It came with the geny built in so I need to utilize it. Does any body have a good source for 12V led lighting or other quality 12v stuff?
Member # 1479
I started asking about one of those higher-end Engel fridge/freezers for my rig.
Apparently they draw very low current compared to many other off the shelf electrical coolers, but they will still drain the average car battery in about 1.5 days. Your electric hot plate would probably draw A LOT of juice compared to an Engel, and you're talking about running a number of electrical devices as well... I'd suggest looking at what everything draws combined, and then figure out how many extra batteries you'll need. Maybe a system with some solar panels to help recharge the batteries as well? Good score on the van though. ![]() Check out sportsmobiles to see what can be done to a f/s van to make it a true expedition vehicle.
Just call me Humpty Dumpty. |
Member # 121833
Got my 12v laptop charger off ebay for cheap... (read <25)
As far as specific vendors of 12v lighting, cannot really help out. All I can say is to look around and see what would work for you. You can also have a battery isolator for the second battery/bank of batteries so that your alternator can charge them while driving. But yeah, if you are planning on doing any cooking or stuff like that, have your generator ready. |
#7 (permalink) | |
Member # 90316
Edit: better link to the two zone:http://undefinedjourneys.wordpress.c...rtment-review/ Last edited by Stumpalump; 01-29-2009 at 11:00 AM. |
Member # 1479
You do need a red star to post.
And I'm aware of the Engels, REALLY nice units, but pricey. That's a purchase I've been considering for this year, but I know I will only use it on one trip in the summer. I'll probably get by this year with the old ice chest for now.
Member # 128317
solar panels!!! I lived in a motorhome for 8 years. Only put 185 hours on the generator. 12v tv's are available, find one digital for the change over. Don't get one, go fishing or read a book. Propane for cooking and frig. Find RV junk yard and get a lot of the stuff. At least two batteries one for engine, one for house. Two 6 volts golf cart for the house work better and last longer. Water is your biggest problem. There are good water filter systems now you can get through back country camping places. I would get rid of the onan. Sell it trade it for a smaller honda, kawasaki. THey are lighter and quieter.If you throw away the roof air. Vents and screens. Learn to sweat. You can probably eliminate the gen. You can get a catalytic propane heater that mounts on the wall. I never slept with the heat on. Too much danger of fire, CO poisoning. You can make a 12v generator out of 3hp engine and alternator. Made my first one for about $40. Rummage sale lawn mower, junk yard alternator, hardware store drive pully, old v belt and hunk of plywood. Called it hoppy. Had to tie it to something or it took off. It will be fun!!!
Member # 90316
The Onan needs to stay. It's built into the side of the van plus it's all wired into breaker box with outlets inside. Just push a button inside and it runs off of the vehicle gas tank. It's heavy but this is a 1 ton van. I need to decide on a house battery and charger. I'll probably just run a Engel 45 12v frige and some interior lighting. I'll be watching the other fridge thread on that. I'm thinking going with just a regular size battery for house. Solar.... that sound good if for nothing else than to keep the batts heathy when it's not being used for a month. Can you use a small 15watt unit and wire it right onto the center tap of the battery isolator?
