Member # 123135
sorry for the stupid question but what are the immediate and long term effects of chassis flexing i was just wondering because I do light off-roading and i was planning on taking my first long trip (4 days or more) so i was wondering just in case because i don't have a roll cage yet. thank you guys for all the help and for giving me your time
Extensive flexing over prolonged time will lead to metal fatigue, but for what you are talking about, there is very little to worry about.
A roll cage is more about protecting you than about stiffening the vehicle up.
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
Member # 123135
the reason i ask is because its a daily driver and i don't want to mess it up too bad. I once had a Dodge Dakota 2002 and affter taking it out about three times off road not even doing any thing crazy it wont go strait
Member # 121833
...also may be a concern for you- some models are prone to rubbing the cab and the bed as the frame flexes... just causes cosmetic issues
Mostest Hardcorest Web Wheeler '84 F250 in progress- D60F D70R 12v Cummins NV4500 4sp Atlas |
#5 (permalink) | |
Make/model of vehicle. suspension mods? tire size? Loaded weight with ALL your gear? |
Member # 86553
you posted nothing about the truck you are speaking of, but is the frame boxed?
all frames will flex a little, but its going to take alot of repetition to permenantly damage the actual frame. as already stated, cargo load, terrain, and the type of frame you have are going to be the biggest factor. if you do light offroading, i doubt it would be an issue. a roll cage is not neccissary, and although a roll cage may increase the ridgity of a frame- a roll cage is more to protect the occupants as opposed to prevent the frame from flexing. Last edited by roastbeef; 06-09-2009 at 03:59 AM. Reason: misread post and edited mine to make sense. |
#7 (permalink) | |
Member # 87150
What kind of truck are you driving now? |
Member # 1479
I beat, and I mean BEAT the hell out of my 2000 Dakota for 3 years and the worst thing I did was bend a driveshaft and cause the t-case to blow.
As was mentioned, it's likely something in your steering setup.
Just call me Humpty Dumpty. |
