#726 (permalink) |
Member # 79921
Cool project. I really enjoyed reading about your grandpa, def a bad ass. Sailboat racing has pretty much been my main hobby for the past few years. Its addicting... Hard to imagine doing those ocean passages in the the time before GPS and modern instruments!
Anyway, donno if its any help, but the way those shitters work on sailboats currently is water is pumped in through the hull to fill the bowl and the selector valve is flipped and it sort of washes/flushes/vacs it down the hole to the holding tank. You repeat till its clean. If you check out a boat store like West Marine they may be able to order you a rebuild kit. I will also second that they stink... On a sailboat using the head is a secondary option at best lol |
#727 (permalink) | |||
fishingwithdynamite
Member # 30721
#728 (permalink) |
Member # 41063
Yeah, I meant Reddot, not sure why I typed Redball. Must have been thinking about hip waders or something, lol.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s |
#731 (permalink) |
fishingwithdynamite
Member # 30721
Posted something a few days ago about how I've been working on a bunch of other projects. Here are a few pictures of some of the stuff I've been working on.
#732 (permalink) |
fishingwithdynamite
Member # 30721
Just uploaded a bunch of pictures to facespace that kinda tell the story behind the GatosBros logo. Spent an embarrassing amount of time on it and it's still not done-done-done, but close enough.
#736 (permalink) | |
fishingwithdynamite
Member # 30721
#737 (permalink) |
Member # 16790
I have a Leece Neville on mine, they are just plain old big. Takes the heat and the load much better, cheap, find them anywhere, they are designed to run harder longer.
For heaters check out Heatercraft.
Earth First.....Then we wheel the other planets! |
#738 (permalink) | |
Member # 86724
I have one as well. Factory rebuilds went to 160A, parts are easy and cheap to come by. Real popular with ambulances and MDT trucks. Hell, you can get a new one at a uhaul location.
ko derf |
#740 (permalink) |
fishingwithdynamite
Member # 30721
If I'm going to build custom alternator mounts, might end up making custom pulleys for the crank and waterpump so that I can convert over to a serpentine belt setup (stock is double V-belts). The Wolverine Tech setup only runs one belt to each alternator, and the alternator pulley shafts run real close to the radiator fan, even after they're machined to create a little more clearance. Making custom pulleys might also make a little more room between the fan and the radiator. That might make it possible to squeeze a fan clutch in there if I can make the pulley setup any shorter. If that doesn't work out, am still really liking the idea of making some kind of remote clutch assembly. Have never seen anything like that done before, but seems like it would be pretty easy to pull-off and I can't think of any reason why it wouldn't work. Would completely eliminate the space constraints, and then I could put a pneumatic clutch on there, or whatever I wanted.
#742 (permalink) | |
Member # 86724
he didn't even take the core because mine was hammered with a bent shaft. did I mention they are cheap? There's tons of room in the case, I'm sure a rebuilder could wind it for whatever amperage you want. Be aware though that the higher amp ones generate a crap ton of resistance before they turn on. Mine slips it's two v belts until it hits turn on RPM, and they're tighter than I'd like already. I'm scared to tighten them anymore for fear of roaching the bearings. here's my old one's guts. ![]() the old guy (80+) at the ignition shop said "that's done" and handed me that mess in a cardboard box. it's nice that the regulator is an add on module, so you can carry a spare voltage regulator and swap it out in a few minutes. It's just held on with 4 screws.
ko derf Last edited by 87manche; 08-14-2012 at 06:31 AM. |
#743 (permalink) |
fishingwithdynamite
Member # 30721
Well the thing is, that's just such small market. We're starting with the KTM's, and then the other major mfg's, and then, if everything goes well, we'll start working on the the more unique applications.
#744 (permalink) | |
fishingwithdynamite
Member # 30721
#745 (permalink) | |
Member # 1602
You may also want to give Rod at San Jose Generator a call. 408 293 2200. Another very cool guy and he knows all things starter and alternator. Mark
Mark E. San Jose, Ca *SOLD* 75 Ramcharger 440, blah, blah *SOLD* 66 Welder Bill't Bronco Rockbuggy 06 CTD 87 Buick Grand National X2 65 Vista Cruiser GN Turbo V6 powered |
#750 (permalink) |
Member # 1602
Be sure to tell Rod that Mark sent you.....
