Member # 115508
Total newbie question on Toterhome Water pressure
Plumbing 101:
Had a quick question about water pressure in RVs and/or Toterhomes. I see most of the water tanks are mounted as close to ground as possible . So how to push water up to sink and shower? what kind of systems are installed to get this to work. Edit: before we go further, I want to know if these systems are pressurized or …..
Jeep 1989 Wrangler -YJ, 4.2L, 5 speed. Breaks down all the time... Last edited by gemer; 06-06-2011 at 03:56 PM. |
There are these things called pumps...
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
Member # 115508
Thanks, That means pump should be running (or be ready on demand) 24x7? are these electric pumps connected to battery or gas run? Do you have any link where they sell them for RVs?
Jeep 1989 Wrangler -YJ, 4.2L, 5 speed. Breaks down all the time... Last edited by gemer; 06-06-2011 at 03:29 PM. |
http://rvbasics.com/techtips/rv-water-pump-basics.html
It works somewhat like the pressure switch on an air compressor. When you open a faucet, the pressure drops and the pump comes on. So when you aren't using the RV, you turn power to the pump off. But when you are going to want water, the pump will be on and ready.
Member # 77042
...that being said, most RV plumbing systems are designed to be able to be hooked up to 'city' water + higher pressures. I have a 25 PSI regulator I use on mine, but it is capable of not leaking at 65 PSI or so.
#7 (permalink) | |
Member # 115508
Jeep 1989 Wrangler -YJ, 4.2L, 5 speed. Breaks down all the time... |
