Member # 140580
Late 70's 5 lug and 8 lug Dana 44 differences
What are the differences between the two? We are planning on swapping my 1977 5 lug outters onto my friends 1997 1500 Dodge and we are going to put 8 lug outters on my 77's 44 so it will match the 8 lug Dana 60 in the rear. Is it just the hubs and bearings or is it the spindle also? Will the lockouts work as well?
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
Member # 37866
Have you tried searching this at all
start here. http://77cj.littlekeylime.com/web_rs44.html
RIP Ein the wheeling Corgi |
#3 (permalink) | |
Member # 140580
Member # 40162
I did just the opposite- 5 lug stuff on a F250 housing. You need to change everything from the steering knuckle out. your 1/2 ton stub shafts will work with the 3/4 ton outers if they are the internal lockouts.
"Time you shut your cake-hole, YOKO!!!" |
Member # 140580
Yeah, they are. Once I do this I have to buy 2 wheels to match my rears as I have 15 inch 8 lugs on the rear and 5 lugs on the front, though they do match, just different pattern. Atleast I will be able to swap my 35's and 33's around and not have to worry about wheel fitment, except some grinding on fitting the 15's on my 96 Dodge 60...
Member # 40162
You could still have fitment problems with 15 inch wheels on the 8 lug Ford setup. That big assed 4 piston caliper requires a lot of space. Someone else could probably say for shure, but seems like I have read that it takes a 3.5 inch backspace wheel to clear that big caliper.
I'm ambient.
Member # 9072
I don't think the '77 outers will fit on the '97 Dodge axle... IIRC, the ball joints on the Dodge axle are captured in the inner "C", and the '77 will have the ball joints in the outer "C" making nothing interchangeable.
#8 (permalink) | |
Member # 140580
Your right, it won't work, oh well, back to the drawing board. Sadly this was stated by a senior member of this board that it would work...
