92 F350 front D60 question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-24-2011, 01:27 AM   #1 (permalink)
Member # 158090
I tried searching the board, and couldn't find the answer. I have a D60 front axle housing from a 92 F350. When I got it, the inner axle shafts, spindles, hubs, rotors were gone. Will the shafts, spindles, hubs, etc off any other Ford front work in the Dana 60 front axle? I was wondering if a later D50 or even a TTB front end possibly having interchangeable parts? I'm thinking about offing this axle, and would like to sell complete.
mattt181 is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 04:24 AM   #2 (permalink)
Member # 83920
You have just a housing, and you want to make it complete, just to get rid of it?
Going to spend a dollar to buy a dime on that deal.
If your dead set on it, pretty much any kingpin axle parts will work, except the shafts. Have to use the later model kingpin shafts because of length.
All in all, It's a retarded idea, but go for it.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 08:36 AM   #3 (permalink)
Member # 68844
Dahoyle is actually right, you will loose money on that. The junkyards that sell Dana 60 parts individually sell them for what they are worth. New parts? Fuhgidaboudit.
Me personally, I would buy what you have now for a severely discounted price so I could build a race ready KP 60 using Reid Racing inner C's and knuckles, Ballistic Fab Double Shear high steer arms, RCV Performance shafts, Dynatrac Lockouts, ARB or Detroit locker, Ruff Stuff cover......
Yeah, I would build that $100 housing into $5000 axle.
[B][SIZE="5"][COLOR="DarkRed"][SIZE="4"]ΜΟΛΩΝ ΛΑΒΕ[/SIZE][/COLOR][/SIZE][/B]
[SIZE="3"][FONT="Arial Black"][COLOR="DarkSlateGray"].308 Winchester: [/COLOR][/FONT][/SIZE][FONT="Arial"][COLOR="Olive"]Turning cover into concealment since 1952.[/COLOR][/FONT]
[COLOR="Blue"][QUOTE=Texas97;13281566]dont know why... unless its some new hippie tree hugger brady campaign sissy ass bedwetter gun control nanny state facist orwellian barbara streisand law that just passed....[/QUOTE][/COLOR]
redpitbull44 is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 12:02 PM   #4 (permalink)
Member # 158090
Thanks for the commentary.....even though I was only looking for technical info. Nah...won't spend a dollar to make a dime....no point in that. I don't know where you are, but I know in my area I can scrounge up parts from other applications for less....if other applications share parts.....which was the whole point of this thread. I know I'm highly unlikely to find another D60 in my normal rounds to scrounge parts off of, which is why I was asking about other Ford front ends that would have useable parts. If I can't find them in my normal rounds....they will be too expensive.
Dahoyle wrote...""pretty much any kingpin axle parts will work, except the shafts. Have to use the later model kingpin shafts because of length.""
Did you mean later model ball joint shafts{this housing has ball joint knuckles}? That sentence seems to conflict with itself....use any kingpin parts, except the shafts, but then use later kingpin shafts.
Ha! $100 housing....uh huh, sure. I'll keep it if that's all you'd say it's worth....but time will prove that out. I was considering keeping it for my truck, which could still happen, but I'd rather have the coin right now.
Old 09-24-2011, 02:30 PM   #5 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
FWIW, I have all the parts to make that housing complete.
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 09-26-2011, 10:58 AM   #6 (permalink)
Member # 158090
I did some part # cross referencing this weekend between D50 TTB, 92 F250 4WD...and....D60 solid axle, 92 F350 4WD....and I found that the hubs/rotors, & calipers are the same between 50 TTB and 60. What I haven't found info on is the spindles....anyone know if they're the same?
On the axle shafts, I'd imagine they're specific since the TTB is a totally different animal, and the later D50 had multiple changes when it hit the Super Duty line.
Old 09-26-2011, 11:26 AM   #7 (permalink)
Member # 45530
any shafts 86-97 from a D60 will work, hubs and rotors will work. Sounds like you have the knuckles so that's not a problem. Spindle has to be for a 92-97 IIRC Unless you've got the best junk yard ever, and with D60 prices right now, I'd look for another axle.
Panthers65 is offline   Reply With Quote Quick reply to this message
Old 09-26-2011, 11:33 AM   #8 (permalink)
KyleQ's Avatar
Member # 83837
Spindles don't swap, but everything rotor out does. Find a floppy 50 and grab everything off the spindle and then all you need are shafts and spindles.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 09-26-2011, 11:34 AM   #9 (permalink)
Member # 112629
any long side shaft will work but not just any short side will work. the outer knuckles are the same as the ttb 50
i have A.D.D. it is problem. um wanna go wheelin.
scott037 is offline   Reply With Quote Quick reply to this message
Old 09-26-2011, 02:14 PM   #10 (permalink)
Member # 158090
I have a line on some Dana 50 front shafts? Work or no work.....from Panthers65 reply I'm thinking no, but figured I'd ask for clarification.
Old 09-26-2011, 08:59 PM   #11 (permalink)
Member # 22267
No, TTB50 Knuckles are not the same as Dana 60 BJ knuckles.
The short shafts are the same from 1985-1997 AFIAK as well (I have swapped them between many times).
BJ 60 spindles will interchange with TTB50 spindles.
TTB50 shafts are not interechangeable with a Dana 60 at all.
Old 09-27-2011, 11:50 AM   #12 (permalink)
Member # 158090
When i mentioned D50 shafts....I was talking solid axle D50, like from a Super Duty. Then it dawned on me the outers on that D50 would be different since the Super Duty used a unitized bearing. So those axle shafts are probably out even though they are from a solid axle front.
There are 2 replies above....one saying BJ60 spindles and TTB50 spindles are the same, and another saying they are not. Anyone know definitively?
I have the knuckles on the axle housing already, so I'm good there.
What I need..... D60 inner shafts, both sides, with outer stubs
spindles
brakes
Old 09-27-2011, 12:41 PM   #13 (permalink)
Member # 68844
I have shitty calipers that need turned in for cores. I'd guess you are not close enough to IN to make use of them, and you would have to live damn near next door for you to come out ahead on them...
Old 09-27-2011, 04:22 PM   #14 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
a 92 should be a Ball joint axle.
Here is some light reading for you.
http://www.pirate4x4.com/tech/billavista/60_front/
Mark
Old 09-27-2011, 06:56 PM   #15 (permalink)
Member # 68844
nice!
Old 09-28-2011, 12:41 AM   #16 (permalink)
Member # 158090
Yep....bj60 it is. Thanks for the link to that article. I had to set this aside and read it tonight when I had the time....that is a long ass article, but lots of good info.
1 vote says TTB50 spindle is the same as BJ60 spindle
1 vote says they're not the same
Any more voters?
Old 09-28-2011, 12:58 AM   #17 (permalink)
dieselboy740's Avatar
Member # 168108
A ttb 50 spindle will work on a Dana 60. I've broken both my spindles and replaced them with ttb50 units. As they are easy to find in the jy.
Knuckles will not interchange.
'97 f-250 project, boat sides, 3/4 link, caged, psd, back halved, dove tailed, fox co/ bumps, etc....
'94 f-350 crewcab, dually, 7.3idi rollalong package
'82 Volvo 242 turbo
'94 international 4700 toter build
dieselboy740 is offline   Reply With Quote Quick reply to this message
Old 09-28-2011, 08:40 AM   #18 (permalink)
Member # 22267
Any more voters?
They are the same. It doesn't matter who votes they aren't. It's a fact they are the same (obviously we are talking pre Super Duty here).
Old 09-28-2011, 06:29 PM   #19 (permalink)
Member # 83920
Yeah, my bad. Had my head up my ass on the switch from kingpin to BJ. Was thinking 92 was last year for KP. Double checked, and was wrong. Still won't make it much easier or cheaper to complete the axle tho.
Old 09-30-2011, 03:09 PM   #20 (permalink)
mjlogan88's Avatar
Member # 23553
Any more voters?
they are not the same but they do interchange. i built an axle just like you did out of a '97 BJ60 and used D50 stuff from the knuckles out
mjlogan88 is offline   Reply With Quote Quick reply to this message
Old 10-14-2011, 09:20 PM   #21 (permalink)
Member # 158090
I found a set of axle shafts from a 79 Ford D60 front axle. I think they would be different from what I need for this 92 axle, but figured I'd ask here for confirmation. Wasn't the pumpkin shifted over on the later D60 vs. the earlier D60(79 vintage)? The 79 axles I found are a good deal and within 25 miles of me.
Old 10-14-2011, 09:51 PM   #22 (permalink)
Member # 133589
78-79 axles wont work the diff is centered more to the center. You need 86-97 shafts.
I hate everybody, don't it feel great.......... to hate?
mvanhelden is offline   Reply With Quote Quick reply to this message
