My Build (Gt Sum 2.5) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-17-2011, 09:26 PM   #1 (permalink)
Member # 174853
After trolling, I figured I’d add my Bronco build up. I had an ’84 in College on 40” Hawgs, and after a long weekend drinking, mudding and seeing pavement pounders, named it Git Sum. Custom painted that on the tailgate in krylon. Ran it for a while, but needed a more reliable truck for traveling, so I got rid of it. I’ve always planned to get another one, but life got in the way. Too much traveling, no place to build a truck, no money, etc etc etc. Last September, I became a bachelor again, and oddly enough had more disposable income after the divorce than while still married, even with a shitload of child support. As I’ve always wanted another Bronco, I started trolling Craigslist. Found this, an ’86 with 6” lift and 35” Mickeys for a song.
This one had 4.10’s, 351W, C-6, BW1356, 9” with a spool, big ass bumpers and a cage. After looking it over, and crawling under it, I noticed the frame bent at the drop radius arm bracket. The body was a POS as well; I put my hand through the roof climbing into it one afternoon. Some of the rust…
Further trolling on Craigslist netted an ’89 with a 302, AOD, 4” list and most of all, a pretty straight body. So I picked it up, backed it in the garage, and got ready for a drive train swap.
git_sum is offline   Reply With Quote Quick reply to this message
Old 10-17-2011, 09:27 PM   #2 (permalink)
Member # 174853
I had both trucks nose to nose, pulled them both down past the core support, and swapped the 351W and C-6 out of the ’86 into the ’89. Motor out…
I also dropped all of the front suspension for parts, and to re-coup some of my money.
Motor swapped into the ‘89
I also used the serpentine belt system off of the FI 302
After getting everything off of the ’86, I had it hauled off for scrap
Old 10-17-2011, 09:28 PM   #3 (permalink)
Member # 174853
I did a lot of this by myself, and am not really good at remembering to stop and take pics. So my story will have to do. The wiring on the ’89 was hacked up in a few places, and I wanted something that would be trouble free, so I gutted all of it. Got a painless kit, and wired it up. Added an Eldebrock Performer manifold, a Holley 750, headers, and an MSD box. After considering the power needs, I ordered a 150 amp (I think) alternator. I found a 10K # winch on craigslist, and picked it up. I also got a receiver mount for it, handy since both bumpers had receivers. I found a set of 38.5” Swampers TSX’s on CL and picked them up. Added a body lift, and installed the cage. I got some racing seats from Summit, real comfy. I wanted to keep mud out of the motor, so I built a skid plate.
Old 10-17-2011, 09:28 PM   #4 (permalink)
Member # 174853
I had it good enough to go day wheeling, had my trailer, and was getting ready to load it up whne the trans took a shit in the drive way. Apparently 5 fluid changes (leaking ass trans pan) removed the clutch material for me. So I had the C-6 rebuilt by a friend of mine with E4OD planetaries and a few other goodies. In the meantime, I added a 2nd battery in the rear, and wired front and rear winch plugs, with a switch in the dash to operate it from the driver’s seat. Here’s a shot of the (mostly) completed interior
Old 10-17-2011, 09:29 PM   #5 (permalink)
Member # 174853
Finally got the trans back in it, clearanced (Clarence) for the tires, buttoned up a few odds and ends, and took it to General Sam’s for a shakedown run. Surely you’ve heard about the drought in Texas. It hit Gen Sam’s too. Fucking dustbowl.
After riding around for an hour, I finally found a fairly innocent looking hole. It wasn’t very far across, I figured it couldn’t be too deep. Wrong. Stuck it.
Sidebar here – the front had a lock rite locker in it, so I couldn’t put the c-clip on the stub shaft for the passenger side axle. It kicked out of the diff pretty quick. The ground was so hard under the mud that I got the front wheels hung at full lock left.
Winched myself out, and assessed the damage.
Carnage included:
E-fans roasted. I had an override off switch wired up, just didn’t hit it. The skid plate, with no holes, acted like a scoop, and pushed a ton of mud into the fans, and burned out the motors.
Front axle – broke driver side u-joint, and the joint in the stub shaft on the passenger side.
Steering box – blew the pitman seal out.
Old 10-17-2011, 09:30 PM   #6 (permalink)
Member # 174853
Note the mud line across the headlights. Hood sat @ 5’ off the ground.
Also found a Natty light can in the front suspension…
Fast forward a month or two, I found a great deal on a rear Rockwell, found another bronco with 44’s, and got an opportunity to work in Colorado for 6-8 weeks. So, I dropped Git Sum off at The Shop Offroad in League City, where it’s getting rocks with leafs, pinion brakes and full hydro steering for the front. I should be getting pics in the next day or so, I’ll post as I get them.
Old 10-24-2011, 03:09 PM   #7 (permalink)
Member # 174853
So they finally got all of my parts in, goth e 44's mounted on the new wheels..
got the front axle in...
And the TTB out, for the most part...
More to come as I get it.
'11 F350 stock.
vos eat caro
Old 10-24-2011, 03:21 PM   #8 (permalink)
Member # 44595
Send a message via MSN to 1badb2 Send a message via Yahoo to 1badb2
cool story!
Rats get fat, while brave men die.
Spare parts? If you're shooting your weapon to failure, it means you're really good to have stayed alive through that much combat. You're not fucked, You're just down a weapon, go get another off of one of the many dead bodies you created
1badb2 is offline   Reply With Quote Quick reply to this message
Old 10-28-2011, 08:13 PM   #9 (permalink)
Member # 174853
And, since I was told I'd wind up with enough room to fit 54's, I figured I'd be on the lookout for them. Arranged to get these today...
'11 F350 stock.
vos eat caro
Old 10-28-2011, 08:45 PM   #10 (permalink)
Idaho4x4Bronco's Avatar
Member # 139619
Attachment 629522
Building a bronco on 54s huh? Sounds oh so familiar lol
Fuck It Sums It Up
Idaho4x4Bronco is offline   Reply With Quote Quick reply to this message
Old 10-28-2011, 08:58 PM   #11 (permalink)
Member # 174853
do you have one? Pics please.
'11 F350 stock.
vos eat caro
Old 10-28-2011, 09:03 PM   #12 (permalink)
Member # 139619
Not yet. Building a 89 on planets with a tube frame on 54 boggers in spring. Should have all the parts by then, close now.
I'll enjoy this build though
Fuck It Sums It Up
Old 10-29-2011, 03:10 AM   #13 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
So what type of suspension? Liking it so far
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's
The Making of a Turd:
huff75 is offline   Reply With Quote Quick reply to this message
Old 10-29-2011, 07:21 AM   #14 (permalink)
Member # 159160
This is awesome
Sent from my DROID2 using Tapatalk
95 F150 that leaves a lot of fluid on the ground
cyclegrip is offline   Reply With Quote Quick reply to this message
Old 10-29-2011, 08:29 AM   #15 (permalink)
Member # 174853
I am going with leafs for this. Its gonna be a mostly mud, some muddy trails. It will have a traction bar, probably to the top of the axle to limit wrap.
'11 F350 stock.
vos eat caro
Old 10-29-2011, 09:33 AM   #16 (permalink)
Member # 139619
I was just thinking that looks like florida. Bloody shame
Gl anyways
Fuck It Sums It Up
Old 10-29-2011, 09:52 AM   #17 (permalink)
Member # 174853
Gl anyways
It may wind up there.
'11 F350 stock.
vos eat caro
Old 11-02-2011, 08:06 PM   #18 (permalink)
Member # 174853
Stopped by the shop today, they have the front axle in place.
Name:  front axle in.jpg
Name:  front axle in 2.jpg
It doesn't look as funny as the pic shows. Ought to be ready to go out in another week.
'11 F350 stock.
vos eat caro
Old 11-02-2011, 09:05 PM   #19 (permalink)
150
Member # 167647
wow that thing is tall. ya it definitely looks like you will be able to fit those 54s
150 is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 10:31 AM   #20 (permalink)
Member # 174853
Picked up my Boggers today, and dropped them off at The Shop. Truck is about at ride height.
Name:  My Boggers.jpg
'11 F350 stock.
vos eat caro
Old 11-10-2011, 01:30 PM   #21 (permalink)
Member # 192361
Thumbs up
looks sick cant wait to see it all done!
RFVeitch is offline   Reply With Quote Quick reply to this message
Old 11-10-2011, 06:42 PM   #22 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
Holy crap those are huge! I think its kinda odd they don't have very deep tread from the factory.
Old 11-14-2011, 02:49 PM   #23 (permalink)
Member # 174853
Finally rolling around. I am going to get drive shafts tomorrow, should finish welding this week, and have anti-wrap bars installed. Hopefully, I can take it out this weekend. It is still sitting on the 44's, easier to roll than the 54's.
Name:  Rolling around.jpg
'11 F350 stock.
vos eat caro
Old 11-14-2011, 03:10 PM   #24 (permalink)
Horsepower Junkie
huff75's Avatar
Member # 173427
Looks kick ass man. First trip, need pics!
Old 11-14-2011, 03:13 PM   #25 (permalink)
Member # 174853
I plan to have pics and video.
'11 F350 stock.
vos eat caro
