Member # 170200
how much with this combo
I got a 302 block from a 97 explorer. (roller motor)
gt40p heads f303 cam bbk shorty headers summit carb intake (edelbrock knockoff) holley 650 What do yall think power wise it is making or is there some other cam I can run to make more power with changing the heads?
Riding threw the swamp something like a Alligator, Buckshots slinging mud like a quarterback! |
Member # 127442
Seams like alot to me but i cant say for sure a stock 97 5.0 is rated 215 crank hp and all you adding really is a cam.
I would keep the efi also just my .02 cent
[CENTER]95 Ranger 5.0L Built 4R70W 203-205 D-60 14B 3 link front 14'' kings 250lb-400lb 63"chevys detroit rear powertrac front 37' creepy crawlers. Build thread here[URL="http://pirate4x4.com/forum/showthread.php?t=878737"]http://pirate4x4.com/forum/showthread.php?t=878737[/URL] [B]Support the BRC![/B][/CENTER] |
#6 (permalink) | |
Member # 127442
Whats it going in? If anyone else has opinions i would like to hear also, seams like most time these 302 with gt heads cam and exhaust are around 250 from what ive read/remembered
[CENTER]95 Ranger 5.0L Built 4R70W 203-205 D-60 14B 3 link front 14'' kings 250lb-400lb 63"chevys detroit rear powertrac front 37' creepy crawlers. Build thread here[URL="http://pirate4x4.com/forum/showthread.php?t=878737"]http://pirate4x4.com/forum/showthread.php?t=878737[/URL] [B]Support the BRC![/B][/CENTER] Last edited by Ford rules; 11-02-2011 at 06:20 PM. |
Member # 168108
Bingo. With conservative timing too. With the p heads and that setup you may be able to toss a lil more timing at it and get a lil better but be stuck running 91.
With that cam I'd get a set of 1.7 rockers too. I ran simular setup in a Volvo that had a 97 sploader motor. But I had 2 turbos hooked to it and efi.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch '90 f-250 project, boat sides, 3/4 link, cage etc '91 Volvo 940se holset turbo, olive drab, lifted rally car |
Member # 127442
How would you bump timing on a coil pack motor never done it before considering he uses the coil packs?
Member # 168108
He will have to put a dizzy in it. I was running megasquirt standalone ECM that controlled the Edis.
Member # 127442
Okay thats what i assumed^
What does Edis stand for?
Member # 168108
Eletronic distribution ignition system iirc.
It uses a 36-1 wheel on the crank to tell the ECM where it's at and it decodes that signal and fires the coil packs. They are actually a wasted spark setup. It always fires 2 cylinders at once. One on the compression the other on the exhaust strokes.
#12 (permalink) |
Member # 127442
Okay figured it stood for something like that.
Yes i figured out the wasted spark setup when i mixed up the plug wires but it still ran fine did some research and found that its the wasted spark setup.
#13 (permalink) |
Member # 170200
This combo is actually for a mustang as a test bed for what I want to do for my ranger. The efi stuff was gone when I got the motor and carb is easier since I dont wanna have to have chips burned and so fourth.
I will test this alot for my ranger and seeing from there. Someone said adding a 1 inch carb spacer will pick up 5 to 25 hp and more tq also. Is this true?
#14 (permalink) | |
6.0 guru
Member # 141621
Cam made. It's worth the extra money. Unless your set on that cam. The alphabet cams are better than stock but there is a lot more to gain from a custom. |
#16 (permalink) |
6.0 guru
Member # 141621
I use hitech, they are around 300$ there are other companies. On my 95 I gained 47 hp swapping a custom in for a off the shelf comp blower cam. They make the cam for your car! They ask ya a million questions and design one for ya.
#17 (permalink) |
Member # 170200
so you had a aftermarket cam and went to a custom cam and picked up 47 over the aftermarket wow!!!
That would put me over 300 for sure
#18 (permalink) |
6.0 guru
Member # 141621
[QUOTE=Built not bought;13565344]so you had a aftermarket cam and went to a custom cam and picked up 47 over the aftermarket wow!!!
That would put me over 300 for sure Well that was in my supercharged 331 with big heads and intake. But you will Def gain more than a f cam. |
#19 (permalink) |
Member # 170200
Well shoot Im kinda lost on this thing and what should be done motor wise with it.
#21 (permalink) | |
6.0 guru
Member # 141621
Stock with the good gt40 heads. So for a truck to be simalar you would need to Convert it to roller cam and get a good one, get some decent heads, decent intake, exhaust and yes it would be comparable. |
