#227 (permalink) |
Member # 217722
the angle i wanted my CO's to lean in (11 degrees) the master cylinder was in the way. like, right where the shock body needed to be. it will be a fair amount of work to move it over 2.5-3 inches, but thats what has to be done.
it didnt actually hit the booster, just the MC. the firewall is angled to the point where it points the MC towards the engine, which makes it even worse. i feel like 11 degrees of lean on the co's is a good compromise between cornering stability and straight line bump absorption. the 3 link doesnt have any natural tendency to resist roll like a radius arm or a parallel 4 link, so i needed to compensate for that by angling the shocks in more than normal. in general- the more vertical the co's are, the better they will absorb bumps at speed. the more angle they have, the better their ability to resist body roll. anyone know of anyone that makes custom AC lines? |
#228 (permalink) |
Member # 219307
I have been watching this thread with one eye closed for some time now, and my other is gettin a lil tired.
Finish this quick, I can't bear to see a FORD turned into scrap iron. ((If I could add smileys, I would add the one crying)) |
#229 (permalink) | |
Member # 217722
![]() once i can get some sort of doubler together, (black box/205 or 203/205) it should be perfect fit. the way it is now, the dshaft clears and everything, but it will be much better when i get a doubler ![]() 1.75 hrew through the frame. both the frame braces are like this. tight fit. also had enough room to push the drivetrain up 1.5" ![]() next ill finish my boatsides and the cage, since i now have a sturdy frame to build off of. Last edited by prosport33; 05-26-2012 at 09:05 PM. |
#231 (permalink) |
party wagon
Member # 202878
so... i guess its about time i ask this again..
is anybody still watching this thing? ![]() updates, i got'em. pic whoring time. trans x member. ![]() thru tubes ![]() welds dont look too bad with paint this time ![]() ![]() ![]() ![]() more as soon as i find the pics i just took
jeep is getting a new home! NEW PROJECT ON THE HORIZON!!! E-350 12 valve cummins, 2006 F350 axles, 6" lift and 37's ... |
#232 (permalink) |
party wagon
Member # 202878
![]() ![]() on to the cool stuff now ![]() lca mounts. ![]() ![]() oops... was i supposed to weld these to the frame? :P ahhh.. muy bueno
#233 (permalink) |
Horsepower Junkie
Member # 173427
FordX-offroad, back from limbo????
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd |
#234 (permalink) |
party wagon
Member # 202878
![]() moar upper control arm time what started out as a poly performance 3rd link bracket. i added to it so it would hold up to 8k lbs of abuse ![]() ![]() ![]() ![]() ![]() ![]() dafuq?? ![]() ahhh.. muy bueno ![]()
jeep is getting a new home! NEW PROJECT ON THE HORIZON!!! E-350 12 valve cummins, 2006 F350 axles, 6" lift and 37's ... Last edited by FordX4-offroad; 06-01-2012 at 07:54 PM. |
#236 (permalink) |
party wagon
Member # 202878
![]() this isn't done, i still wanna tie the upper mount to the trans x member.. just because... ![]() ![]() and one last pic showing the belly height and whatever.. need to make a trans skidplate, and something to half ass protect the tcase (so i can make my van 4x4 at a later date )![]() okay, im done now ![]() commment away
#237 (permalink) |
Marines deleted mine
Member # 84339
Looking pretty.
You shoulda come over and welded up my panhard bar
The definition of irony: http://www.pirate4x4.com/forum/attac...1&d=1334801294 Yeah, Janelle R Becher is a cunt
#238 (permalink) |
trial and error
Member # 107096
let me know how the trans cross member works out. I may copy it.
cowboy up "life's alot tougher when your stupid" - John Wayne 1988 Ford F-250 6.9 diesel, zf 5-speed, bw 1356, bastardized suspension, hp kp 60 w/ 4.56 and detroit, rear 10.25 w/ 4.56 and detroit, 38" Interco ssr's, cm ss flat bed http://www.pirate4x4.com/forum/ford/...bler-tech.html |
#239 (permalink) |
Member # 46318
Well done!
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html 1979 F-350 build: /forum/ford/855113-79-f-150-build.html |
#240 (permalink) | |
party wagon
Member # 202878
DROID...
#241 (permalink) | |
party wagon
Member # 202878
I got tired of seeing the mediocre xmembers that bolt to the bottom or sides of the frame rail and offer very little structural support to the frame. So I think it will work well. :fingerscrossed: DROID...
#242 (permalink) |
party wagon
Member # 202878
Thanks! I'm getting pretty excited about it.
DROID...
#245 (permalink) |
Member # 168108
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch '90 f-250 project, boat sides, 3/4 link, cage etc '91 Volvo 940se holset turbo, olive drab, lifted rally car |
#247 (permalink) |
party wagon
Member # 202878
Mini update
The frame gets about an inch and a half smaller in cross section height from any other point on the frame right here. So I thought since I want this to do everything crawling/gofast, and its really heavy. I fixed a potential weak spot when I fly this pig ![]() Then I added a gusset.. or 6 ![]() ![]() ![]() ![]() DROID...
#249 (permalink) |
Member # 187456
So you ever going to get to the rockers?
Everything else looks good n beefy though..
[QUOTE=bigford;10609690]On a side note: I remember telling my second ex wife " My truck comes first, then my job, then you " I never liked that woman. [/QUOTE] |
#250 (permalink) | ||
party wagon
Member # 202878
i dont really see any overkill, maybe the plating on the frame, but it's a heavy truck. i kind of have an idea on what your wanting to accomplish with your truck, so i personally do not see any overbuilt areas on your truck. this may sound "einstein-ish" but, everything is relative; are you wanting to crawl the curb at the local mall? if so, just put a few tac welds on everything. wanting to survive weeks on end out in the desert while continually beating on your rig? better make sure the modifications you've performed are the LAST thing that breaks/ wears out. i believe you will agree for the most part. Quote:
i was going to pick up a working c6 and 205 tomorrow, but its 3 hours away and i dont need it for another few months, running out of money, and would rather spend the 6 hours working on my truck instead of driving... ![]() i basically have everything bought that i need to finish, but there is always little shit that makes you go broke.
