78 ford build/truggy - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-11-2011, 06:53 AM   #26 (permalink)
Member # 104270
Honestly I'd keep going with the tube and make it an exo. Looks killer.
Fueled by Hate, caffeine, and sometimes whiskey.
My Junk.
http://www.pirate4x4.com/forum/showt...229&highlight=
br0nc0xrapt0r is offline   Reply With Quote
Old 11-13-2011, 05:32 PM   #27 (permalink)
shannondeese's Avatar
Member # 153031
I just started on a 1979 F250 so keep going. I like to looks so far.
1978 Chevy 3+3 - 1985 M35A2 4X4
shannondeese is offline   Reply With Quote
Old 11-20-2011, 06:34 PM   #28 (permalink)
Member # 171834
added a few more braces to the cage and side ones, tap for the prop valve and mounted the tool box, fished alterntor bracket, rads finished. just need to get a new 1410 yoke for the rear and some straps and she's moving!!! then just little things like mud proof engine bay and put a floor down in the back, wire in rear lights and make some temp fenders and baboomshaaa she's done!! and ready for the toy run!!!
i think that 45 degree rci fill neck will work perfect!!
78 ford f350. d60 14b 429 cobra jet in boarded chevy 63's truggy
jordanbenntt is offline   Reply With Quote
Old 11-20-2011, 06:39 PM   #29 (permalink)
Member # 171834
got the big ol rad mounted on some custom bracket and a good cross brace and also got the fuel cell mounted and straps made
Old 11-22-2011, 03:41 AM   #30 (permalink)
Member # 104270
Idea for the filler neck, cut a hole and run it strait up into the tool box. That way you can lock the box and help keep assholes from stealing your gas. Just a thought since it's happened to me.
My Junk.
Old 12-06-2011, 10:47 PM   #31 (permalink)
Member # 171834
well managed to get some box sides from classic auto wrecking in langley!
so i got em home cut them up and started to create something. took 10'' out of the front and 11 1/2'' out of the rear, and then 4'' around the wheel well. little bondo and paint and then mounting! hopefully have them done for this weekend, snow wheeling!!
light mock up just sitting on tire. but you get the idea
Old 12-06-2011, 10:52 PM   #32 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
finally some updates!!
i like the bed sides, how about boltin those puppies on so we can see what it really looks like
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 12-07-2011, 12:45 AM   #33 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
BOO! maybe it's just the hillbilly in me, but i hate the doved bedsides covering up cool tube work and shit. truck was cooler with out skins.
p.s. same to you allgonoshow.
web wheeler 4 life.
Originally Posted by Fudpucker View Post
I'm disappointed You're nowhere near as fat as i had expected you to be.
Ugly, sure, but not all that fat.
Originally Posted by JabNasty View Post
fatdan I have no idea what your trying to say and thats goes for about 90% of the shit you post.
fatdan460 is offline   Reply With Quote
Old 12-07-2011, 09:06 AM   #34 (permalink)
Member # 171834
ahha i can't agree with you more, but for driving on the street it was a bit sketchy, don't worry ill make that look good and still need to add some cage work, she will be purdy....untill the first tree!!!!!
also getting my bead locks today too weeeee
Old 12-07-2011, 02:52 PM   #35 (permalink)
AllGoNoShow's Avatar
Member # 46318
HAHA, well I like em Dan When the shit gets real, the bedsides on my truck can be removed with 4 bolts per side, literally a 5 minute job. There will be some more tube added to mine when I get time. I like the bedsides Jordan!
Project Ol' Skool '37 Chevy: /forum/ford/1049898-project-old-skool.html
1979 F-350 build: /forum/ford/855113-79-f-150-build.html
AllGoNoShow is offline   Reply With Quote
Old 12-07-2011, 03:37 PM   #36 (permalink)
Member # 171834
cheers man you too!
hey hows the propane so far?
Old 12-07-2011, 04:24 PM   #37 (permalink)
Member # 46318
The propane is awesome, one of the best upgrades I have ever done.
Old 12-07-2011, 06:14 PM   #38 (permalink)
Stay the Trail
mrboyle's Avatar
Member # 3937
Damn good lookin truck!
Mike Boyle
1980 Toyota PU
"Those who hammer their guns into plows will plow for those who do not..." - Thomas Jefferson.
Battlement Fab
mrboyle is offline   Reply With Quote
Old 12-15-2011, 09:15 AM   #39 (permalink)
Member # 171834
well got three of the four headlocks mounted, what. a. nightmare.
after getting the first one mounted and filled i herd the worst.. ssssssssssssss..
dammit! there was a leak pulled everything off and found the pin hole son of a bitch! welded and were good, but good thing i check the other cause one rim had a few pin holes bubbling. here was the headlocks through the steps
i used washers all around to line up the ring as best i could.
after tacking a welded stitches in a criss-cross pattern
the first weld only filled about 80% of the valley so i had to do another lapgo fuck yourself
nik (procircuit) grinding a way! thanks man..
man they look so cool. but I'm nervous about how they are going to drive.. i tired my best to line up the tire but i have a bad feeling they are going to wobble
more pics to come..
Old 12-15-2011, 09:16 AM   #40 (permalink)
Member # 171834
grinded and painted
primed and painted white
and then the fun part... mounting.. fuck.
done (but then had to pull for leak ) hahahere is a photo of that little bastard, i used oil around the top of the ring and a air gun under blowing up to see bubbles and found it,drilled and filled and no leaks, for now ....i torqued them to about 17fps.. conned them a little more than liked but it should be okay, i should have made a filler for the inside of the lip but will see how bad it is..
Old 12-15-2011, 12:37 PM   #41 (permalink)
Banned
Member # 206038
I like it! I always thought that the whole point in tubing the rear was so you could chop the frame behind the cab, link it and have a better departure angle because you don't have to mess with a rear hanger and the extra length. Def bad azz though!
likmytaint is offline   Reply With Quote
Old 12-15-2011, 03:17 PM   #42 (permalink)
Member # 197717
I like that you got beadlocks that are just plain, I hate beadlocks that have some bad ass pattern in the bk you fight with them airing down and airing up, good thinking
janderson4010 is offline   Reply With Quote
Old 12-15-2011, 04:59 PM   #43 (permalink)
Member # 127442
Truck looks awesome, i like the bedside they look bad ass
[CENTER]95 Ranger 5.0L Built 4R70W 203-205 D-60 14B 3 link front 14'' kings 250lb-400lb 63"chevys detroit rear powertrac front 37' creepy crawlers.
Build thread here[URL="http://pirate4x4.com/forum/showthread.php?t=878737"]http://pirate4x4.com/forum/showthread.php?t=878737[/URL]
[B]Support the BRC![/B][/CENTER]
Ford rules is offline   Reply With Quote
Old 12-16-2011, 05:45 PM   #44 (permalink)
adpdesigns's Avatar
Member # 193039
truck is way cool for sure ! cant wait to see more pic's !
adpdesigns is online now   Reply With Quote
Old 12-18-2011, 07:22 AM   #45 (permalink)
Member # 113388
Damm thats alot of money in bolts.... sick though
weswes01 is offline   Reply With Quote
Old 12-18-2011, 05:35 PM   #46 (permalink)
Member # 146152
This thing is sick...and I LOVE the bedsides. Yeah the tubework is awesome, but it still resembles an old ford with the bedsides on. I love me some old fords!
"You're here for a good time, not a long time."
swampshaker99 is offline   Reply With Quote
Old 02-23-2012, 07:43 AM   #47 (permalink)
Member # 171834
It's now forsale if anyone is interested here a a link to the forsale post.
http://www.pirate4x4.com/forum/showt...073&highlight=
Old 02-23-2012, 10:58 PM   #48 (permalink)
Member # 128169
pretty fuckin slick
Old Ford Turd Pickup
BACRAKR is offline   Reply With Quote
Old 04-16-2012, 09:14 AM   #49 (permalink)
Member # 195664
wanna sell your fuel cell. i live in bc and need one! thanks.
blazing_yota123 is offline   Reply With Quote
