1993 bronco 5.8 choking on gas - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-09-2011, 09:59 AM   #1 (permalink)
Member # 84271
1993 bronco 5.8 choking on gas ! HELP !
I have this bronco that loops after starting up for a minute then settles down with a rough idle.
it runs just like it had a carb with a stuck choke. you can stomp the gas pedal and smoke comes out the pipe smelling strong gas..
things I did
replaced the map sensor twice
replaced the idle air controller
and the coil and wires
and the water temp sensor and air sensor
all plugs are black carboned over evenly with a odor of gas as was the Oxygen sensor.
checked fuel regulator vacuum for gas leak.
HELP
junker is offline   Reply With Quote
Old 11-09-2011, 10:13 AM   #2 (permalink)
Member # 192650
maybe fuel injectors are dirty
jamesmoss is offline   Reply With Quote
Old 11-09-2011, 10:45 AM   #3 (permalink)
dieselboy740's Avatar
Member # 168108
Throttle position sensor.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch
'90 f-250 project, boat sides, 3/4 link, cage etc
'91 Volvo 940se holset turbo, olive drab, lifted rally car
dieselboy740 is offline   Reply With Quote
Old 11-09-2011, 11:04 AM   #4 (permalink)
Member # 82896
did you check your oxygen sensors? They can get wiped out from a rich condition. You could have fixed the problem but destroyed the oxygen sensor too?
baker84 is offline   Reply With Quote
Old 11-09-2011, 09:22 PM   #5 (permalink)
Hardcore Web Wheeler
Whitetrash303's Avatar
Member # 102426
Have you checked fuel pressure? Pinched or clogged return line will make it rich. Have you pulled codes? Did you check the FPR while the engine was running? Does it have a MAF sensor? (rare, I know)
The Answer to 1984 is 1776
Whitetrash303 is offline   Reply With Quote
Old 11-11-2011, 08:39 AM   #6 (permalink)
Member # 185304
the same thing happened to me and it ended up being a vaccumm line that melted
4xFord26 is offline   Reply With Quote
Old 11-11-2011, 04:43 PM   #7 (permalink)
Cactus Farmer
Dr.Danger's Avatar
Member # 168243
Did you try to diagnose anything before throwing parts at this thing blindly? Pulling codes should have been the first thing you did. Honestly man, why would you replace ANOTHER mass air sensor after replacing one already, and it not fixing it?
You might be better off paying someone to figure this out for you seeing as you like throwing money around.
-Dave
Dr.Danger is offline   Reply With Quote
Old 11-11-2011, 05:03 PM   #8 (permalink)
Member # 135508
This.
Sounds like a blown FPR to me, you sure there is no gas in the vacuum line?
Unskinny Bop...All night and day
RacinNdrummin is offline   Reply With Quote
Old 11-14-2011, 12:58 PM   #9 (permalink)
Member # 61938
gotta check fuel pressure both with key on and with engine running. i bet the fuel pressure is really high. check your oil, if you smell gas do not drive or turn it over until you do an oil change. if gas gets on the crank,rod bearings they will wash and get ruined causing motor failure.
94 Bronco 5.8/E4OD 6" Stage II 35" BFG
4.88's / Front Aussie/ Warn HS9500I
kemicalburns is offline   Reply With Quote
