Swag Sales
Member # 90594
Shaving a divorced 205...the drapes not the carpet.
So I have a 205 I’m putting in a XJ buggy. To clock it flat the factory mounts are going to create clearance issues. Can I cut the mounts off (red) and make a mount bolting it to the exterior bolts on the front and back (yellow) like the Toyota guys? That picture was from google so I dont know what they have going on on the bottom side left already but I will use more bolts then that. Yes, I have searched. Thanks guys!
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! |
Horsepower Junkie
Member # 173427
I have never been in a divorced case but I would pull it apart and check it. My guess is that you can grind it down as long as you don't make the case any thinner than the rest of the case. As long as its apart pull the shift rails and mod them for front drive. The mount in the pic on the right in the red. I would leave it if at all possable and use it with the new brace as it will be strong. I am guessing you are clocking it up. I would drill the PTO cover and weld on a bung with a plug. Use this as the new fill hole as the stock one will not be enough anymore. You could also buy a new cover from Northwest Fab as they already have this.
75 F250 40 inch LTB'S D60 front W/spool Fordteen Bolt rear W/ Grizzly 5.38's Rear 4-Link /w 16" FOA's in progress The Making of a Turd: Huff's Green Turd |
#3 (permalink) | |
Swag Sales
Member # 90594
Member # 83920
Cut as much as you like. Just be prepared to plate over the hole you create, after fully disassembling the case to ensure you aren't filling it with grindings and welding splatter.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. |
#6 (permalink) | |
Swag Sales
Member # 90594
Will the input swap to the married 205?
Member # 83920
I don't remember the bearing size on the divorced case, but it's easy to tell.
Pull the yoke off the Ford input, and then remove the bearing retainer. Then pull the bearing retainer off the GM case. If the outside diameter of the bearings is the same, then it'll all swap. Either way, you need to spend some time deciding how you are going to mount the thing.
#8 (permalink) | |
Swag Sales
Member # 90594
#9 (permalink) | |
Member # 83920
Still need to check the bearing size, or look up the input bearing number. I have both at the house, but don't remember if the divorced case uses the large or the small bearing.
Horsepower Junkie
Member # 173427
Divorced case is a small bearing. Has a male input for the yoke.
#12 (permalink) |
Swag Sales
Member # 90594
I already have both style cases but I dont want to cannibalise one of them to make the married one divorcedif I can just trim the divorced unit. Plus I would bet its harder than you make it sound.
#13 (permalink) |
Member # 83920
That's what I was thinking. It's been awhile since I looked at the divorced guts, and I'm working out of town so I couldn't check. Uh, no you can't. That was the entire reason for checking the bearing size. A married Ford case is a large bearing. No way to install a small bearing input without doing some hack bulshit like a spacer or something. Just because it is 32 spline, does not mean it's a big bearing. Divorced is different.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. Last edited by dahoyle; 12-13-2011 at 04:44 AM. |
#14 (permalink) | |
Member # 83920
As to cutting the case. I already told you. Get the case, cut off the offending mount, weld a plate over the hole, and put the guts back in. How about you do some work for yourself now. Pull the studs, and measure the depth of the holes. I would guess that would be close to the limit to how much you can cut off without leaving a hole which must be plated. Another possibility is to use a divorced Dodge case, and swap sides. Take the two clusters out, and swap them in the casing. Dodge and International cases don't have that massive protrusion. There are any number of ways to do what you are trying to do, but you have to get your hands dirty, and you WILL become familiar with the insides of a 205.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self. Last edited by dahoyle; 12-13-2011 at 04:57 AM. |
#15 (permalink) | |
Swag Sales
Member # 90594
I did search divorced ford 205 mounts multiple times on here and google but all of them are using the top bolts. Ill tear into it and let you know. Im about a month away from even dealing with the transfercase. I still need to get the motor and transmision put in first!
#16 (permalink) |
Horsepower Junkie
Member # 173427
My only concern with grinding the mount was if the case, when it was cast, had that mount completly solid to the top or if part of it was cast hollow and only the last inch or so was solid for the bolts. For it to be hollow would not make sense but ther is a lot of shit the factorys have done that did not make sense. But even if it is hollow, cut it. Like Dan said, plate it afterwards.
#17 (permalink) | |
Swag Sales
Member # 90594
Ill give it a shot and report back! By fried has a porta-band saw that will make quick work of the project!
#18 (permalink) |
Swag Sales
Member # 90594
I cut 1.5" off the drivers side which was how deep the bolt holes were. Cut the passengers side flush. Going to build the mount off the pto port, rear inspection cover and front output.
FITS ALOT BETTER NOW!
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! Last edited by dozer_xj; 01-02-2012 at 04:34 PM. |
#19 (permalink) |
Swag Sales
Member # 90594
Here is a pic of progress
#20 (permalink) |
Swag Sales
Member # 90594
Just noticed I never updated this (bringing it back from the dead!!!!)
![]() ![]() ![]() It worked great but I ended up selling the project after wheeling it only once!
