Member # 206290
Traction bar fabrication
Hey guys I'm looking at building some traction bars for my bronco and I'm looking for ideas
Maybe some of you have fabricated your own set so I would appreciate any help I have just put in a dana 60 up front sas conversion with a rear sterling10.5 I was told I would be needing them so I'm going to build a set soon ill post pix of my build but for now thanx
Member # 168108
My brain hurts.
You did all of that but you cannot figure out a traction bar? There actually isn't a lot of information if you search. I searched and searched for ever before I got the one I run. I got the "kit" from ruffstuff.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch '90 f-250 project, boat sides, 3/4 link, cage etc '91 Volvo 940se holset turbo, olive drab, lifted rally car Last edited by dieselboy740; 12-15-2011 at 11:06 PM. |
#5 (permalink) | |
Member # 54530
To the original poster you only need one traction bar. Put it as close to center as possible and make sure the top mount is threaded, that way it still can articulate with joint tightening/ loosening and the shackle allows for suspension movements up and down. I used 1/4 wall Dom tube with a ballistic 1.25 threaded joint and two weld on bushings at the diff. Another cool idea is this!! http://www.jeepaholics.com/tech/bambar/
73 F-250 44's,428,twin sticked 205,60 fr,70 rear,ARB/Detroit,crossover high steer/hydro assist,winches |
#6 (permalink) | |
party wagon
Member # 202878
i like dieselboy's anti wrap bar because it also serves as some protection to the rear DS
jeep is getting a new home! NEW PROJECT ON THE HORIZON!!! E-350 12 valve cummins, 2006 F350 axles, 6" lift and 37's ... |
#7 (permalink) | |
Banned
Member # 206038
Member # 168108
I dont see how that jeep one wont bind.
Looks like on leaf springs it would unless the shackle is the same length as the front of the leafs. In my eys as the suspension travels it would want to follow the arch of the shackle. Imo that doesn't match the leafs. Its ok if you have no travel.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch '90 f-250 project, boat sides, 3/4 link, cage etc '91 Volvo 940se holset turbo, olive drab, lifted rally car |
AF6 OD
Member # 46467
WFO sells a kit too that it close to the RS version, but is a bit different with an extra hem joint. It also has a cross brace in part that welds to the axle.
some pic's from there webpage. Buy / Build. having ideas help
73 IH Scout |
