1991 Ranger 1 ton 3 link build - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-30-2011, 04:35 PM   #26 (permalink)
Member # 1408
Send a message via AIM to RockRanger
I like how you did your coil over mounts. Your three link looks a lot like mine and I really like how it works.
93 Ranger on 37"s
RockRanger is offline   Reply With Quote
Old 12-30-2011, 07:55 PM   #27 (permalink)
Member # 110387
Send a message via MSN to WildStyle
Thanks. They seemed like the easiest option to fit into the truck without re locating a bunch of stuff.
WildStyle is offline   Reply With Quote
Old 12-31-2011, 07:38 AM   #28 (permalink)
Rockcrawler_101's Avatar
Member # 11955
Looks good! You might want to run joints on both sides of the top link. I ran one joint and one bushing on my three link on top link and when flexing it distroyed both bushing and joint the first time out
48 willys pickup on 1 tons, 5.8L and 44's. 01 ford superduty 4x4 6 speed.
Rockcrawler_101 is offline   Reply With Quote
Old 12-31-2011, 03:15 PM   #29 (permalink)
Member # 110387
Will keep that in mind. Thanks!
Sent from my GT-S5830D using Tapatalk
91 Ranger - One tons, 3 link, air shocks, 40's....under construction
Old 01-03-2012, 10:32 PM   #30 (permalink)
Member # 110387
Alright....steering is sorted out. Ended up going with a stock ranger pitman arm and reaming it out for the chevy 1 ton tie rod mounted on top of it. It is an extreme angle tie rod end and has lots of side to side travel. If I mounted it under as it was stock the tie rod would contact the tie rod end under full stuff.
Started on the track bar mounts and bar tonight. Got the bar fabbed and the joints tacked onto it. The axle end will mount through the web of the truss itself, and I will build around it to make it in double shear. I started on the frame end mount as well. Got it all fabbed and welded together, just needs the holes drilled and to be welded to the frame and a bit of bracing.
Old 01-03-2012, 10:47 PM   #31 (permalink)
Marines deleted mine
Pt_Ranger_V8's Avatar
Member # 84339
Looking good man.
How much was the reamer? I might do a similar flip on my crew cab, just to ease things a little bit.
The definition of irony:
Originally Posted by gee whizz View Post
your retarted.
Originally Posted by southernfriedcj8 View Post
I love the erection pics!
http://www.pirate4x4.com/forum/attac...1&d=1334801294
Yeah, Janelle R Becher is a cunt
Pt_Ranger_V8 is online now   Reply With Quote
Old 01-03-2012, 11:14 PM   #32 (permalink)
Member # 110387
Originally Posted by Pt_Ranger_V8 View Post
Looking good man.
Reamer was free....borrowed it from a buddy who bought it to flip his tie rod a while back. From what I've seen they can run anywhere from $50-100.
Old 01-04-2012, 08:39 AM   #33 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
Originally Posted by WildStyle View Post
did you put the axle at full stuff with your tracbar like that? if its not it kinda looks like maybe the tracbar will possibly hit the diff? idk...
i see so many times where the extra time is not taken to prep the metal and it makes me
im glad to see youre taking the time to get the metal clean in the areas to be welded together.
jeep is getting a new home!
NEW PROJECT ON THE HORIZON!!!
E-350
12 valve cummins, 2006 F350 axles, 6" lift and 37's
FordX4-offroad is offline   Reply With Quote
Old 01-04-2012, 12:09 PM   #34 (permalink)
Member # 141906
Send a message via MSN to Flatdeck6.2
Howdy neighbor.
I haven't seen many builds around here of this caliber.
Where do you wheel? Maybe I'll run into you in my travels this summer.
Edit: Im over here in sunny Prince Rupert by the way
Living vicariously through you
Flatdeck6.2 is offline   Reply With Quote
Old 01-04-2012, 12:15 PM   #35 (permalink)
Forever being built
wahlstrom1's Avatar
Member # 94308
He's up in Terrace.... Now onto the thread jack!
Flatdeck6.2, you wouldn't by chance have bought a set of goodyear RT II's for your truck in Red Deer a couple years back? Truck looks oddly familiar...
wahlstrom1 is offline   Reply With Quote
Old 01-04-2012, 12:48 PM   #36 (permalink)
Member # 141906
Thats me. Back when my truck was a reliable daily driver, those tires did me good. Still got them in the back yard somewhere.
I met you on 4wheeler.ca back when it was still alive
sorry for the hijack
Old 01-04-2012, 06:00 PM   #37 (permalink)
Member # 110387
The axle is sitting against the bump stops in that picture. The tracbar will sit up about an inch or so away from the top of the housing at full bump.
And yup, everything gets ground shiny before I weld it.
Old 01-04-2012, 06:02 PM   #38 (permalink)
Member # 110387
Originally Posted by Flatdeck6.2 View Post
Howdy neighbor.
Sunny Prince Rupert
I wheel locally and we usually head out and hit up Red Rose mines and the Telkwa pass once in a while.
Old 01-10-2012, 11:59 PM   #39 (permalink)
Member # 110387
Alrighty....it is almost of the stands! I just need to grab some bearings from work, and get the hubs on and bolt the tires on. I will try and get my nitrogen tank/regulator and hose set up on thursday so I can get it off the bump stops.
Old 01-11-2012, 12:19 PM   #40 (permalink)
Kyle M's Avatar
Member # 165077
Good work, looks nice.
93 RANGER 4D'S/V8/TONS
Kyle M is offline   Reply With Quote
Old 01-12-2012, 11:21 PM   #41 (permalink)
Member # 110387
Well got my nitrogen bottle/hose today...grabbed an old regulator we had at work. Seems it is fubar and barely puts out any nitrogen pressure. Also found my steering binds at the pitman arm near full droop, seems I won't be able to use the full 14" of travel these shocks have. Also the passenger side shock body hits the frame at full droop at the track bar pulls the axle to the drivers side. This is due to the shorterish track bar, but there isn't much I can do there...it is the same length and parallel to my drag link which is exactly what you want for no bump steer. I can move the lower mounts out on the axle about an inch to 1.5" more to give a bit more room. Looking like I can limit strap it to 12" of travel and that will help a lot as well, or try and trade my 14" shocks for some 12"ers.
Old 02-23-2012, 09:20 PM   #42 (permalink)
Forever being built
wahlstrom1's Avatar
Member # 94308
and here too....
Old 02-23-2012, 11:53 PM   #43 (permalink)
Member # 110387
Fer fawks sakes....you must have been bored!
Old 02-23-2012, 11:59 PM   #44 (permalink)
fastg60's Avatar
Member # 38567
Send a message via AIM to fastg60
Looks pretty good. Lots of good ideas and quality work.
WANTED: 30' ish bumper pull trailer near 45342
fastg60 is offline   Reply With Quote
Old 02-24-2012, 12:15 AM   #45 (permalink)
Fordman500's Avatar
Member # 56456
Looks good man, lower link brackets appear a bit thin though, what size are they? Nice work with the axles though. Panhards suck IMO, its hard to stuff a long one under and clear everything, then you go with a short one and it jacks the axle one way quite a bit. I am having the same issue with mine as we speak.. Wish I could do a watts link like the race car.... hehe
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote
Old 02-24-2012, 01:00 AM   #46 (permalink)
Member # 110387
You talking axle end or frame end? They are both made from .250 plate...the axle brackets are from TMR, the frame end I built.
Ditching the tie rod steering and going heims. Drag link will be stacked ontop of the tie rod heim and the knuckle will be getting gusseted to make it all double sheer. This will lengthen the pan hard and drag link roughly 6". It will also make both sit flatter. Hopefully this will solve the binding issues I'm currently having.
Old 02-24-2012, 04:58 AM   #47 (permalink)
Member # 151685
He must have. LOL
Sent from my EVO using Tapatalk
escort_gts is online now   Reply With Quote
Old 02-24-2012, 06:07 AM   #48 (permalink)
Member # 211410
Nice work!
wyman00 is offline   Reply With Quote
Old 02-25-2012, 09:52 AM   #49 (permalink)
Hillbilly Redneck
302B4's Avatar
Member # 173422
Awesome build. Lots of good stuff in here.
Got some questions for ya.
What length are the links?
What did you set the caster at?
What gears and lockers are you going to run?
Thanks man
99 Mazda
302 T18 NP205-TS 60/10.25 42 TSL's
302B4 is offline   Reply With Quote
Old 03-30-2012, 10:32 PM   #50 (permalink)
Member # 110387
Links are all 38" long .250 2" DOM
Caster is sitting at 6 degrees right now.
Will be running 5.38's with Yukon Grizzly lockers front and back.
