2006 Ford Dana 60 Front axle Locker? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-25-2011, 12:16 AM   #1 (permalink)
Member # 207010
I am confused for all Detroilt products refer to 4.10 and lower and 4.56
and higher however I'm running a 4.30 front and rear in my truck with
38x15.50R18 tires. I currently have a TrueTrac in the rear right now and
am looking rebuild my front axle with all new seals and ball joints and
was going to put a locker or TrueTrac in it since it will be all broken
down. I am swinging more towards the locker than the TrueTrac but would
like an opinion from someone else too. I do alot of offroading in the
mud and snow. I been stuck twice, once in a very deceiving puddle of mud that was just a real bad call and then once it slid into a off road rut lifting the right rear wheel off the ground causing the TrueTrac to show off its bad side and one front tire was unloaded and just kicking up dirt while the other didn't move...
Any help would be great.
Thanks,
Patrick
patrickrc51 is offline   Reply With Quote
Old 12-25-2011, 12:23 AM   #2 (permalink)
dieselboy740's Avatar
Member # 168108
Ugh I'm not feeling it...
For a front axle on a driver get a selectable locker. Aka arb, or e-locker.
I have the e-locker in mine and love it.
97' f-250, 7.3psd, extracab, 30" out of frame, dana 60 e-locked, 10.25", rear disc conv, 14'' profender shocks, 37s dbl beadlocks, intake, 3" dp to 5", dpf5 tuner, 12k winch
'90 f-250 project, boat sides, 3/4 link, cage etc
'91 Volvo 940se holset turbo, olive drab, lifted rally car
dieselboy740 is online now   Reply With Quote
Old 12-25-2011, 12:28 AM   #3 (permalink)
Member # 207010
Thats the thing... no matter my choice in E-Locker, Locker, Truetrac EVERYONE is selling the products as such: For gear ratios 4.56 and higher use this part number X
For gear ratios 4.10 and lowever use this part number Y
What the hell part number am I to use if I have 4.30's in my truck...
Do I have to switch my gear ratios front and rear just to have an option in locker devices or am I stuck with the open dif that came with it...
Patrick
Old 12-25-2011, 12:42 AM   #4 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
yes.
web wheeler 4 life.
Originally Posted by Fudpucker View Post
I'm disappointed You're nowhere near as fat as i had expected you to be.
Ugly, sure, but not all that fat.
Originally Posted by JabNasty View Post
fatdan I have no idea what your trying to say and thats goes for about 90% of the shit you post.
fatdan460 is online now   Reply With Quote
Old 12-25-2011, 12:46 AM   #5 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
no.
web wheeler 4 life.
Old 12-25-2011, 12:47 AM   #6 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
maybe.
web wheeler 4 life.
Old 12-25-2011, 12:52 AM   #7 (permalink)
Member # 168108
It may use the 4.10 from what I found. But to be sure I'd do what the easiest thing to do in a situation like this. Call them.
Old 12-25-2011, 12:57 AM   #8 (permalink)
Member # 207010
I think your right... What I was just reading makes me think because the truck came with the 3.73 gears and I never switched the carriers to a high gear or made a gear thickness change I would still use the 4.10 and lower carrier. When I replaced the gears I used Ford Motorsport gears to keep it as stock as I can for this reason alone... I sent out a bunch of E-mails; Eaton, ARB, a couple of Ring and Pinion folks too... We'll see what they all say but I'm totally over the open diff in the front...
P
Old 12-25-2011, 01:04 AM   #9 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
web wheeler 4 life.
Old 12-25-2011, 01:07 AM   #10 (permalink)
Member # 207010
Well I never changed the Carrier in it. It came from Ford with 3.73's and aside from normal shimming of the 4.30 gears it went right together.
P
Old 12-25-2011, 01:08 AM   #11 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
P
well now you are a fuckhead.
web wheeler 4 life.
Old 12-25-2011, 01:14 AM   #12 (permalink)
Member # 207010
Whats your deal, You finish your mid-night drunkin jerk session and now your trying to play funny forum guy... Not working Spanky...
P
Old 12-25-2011, 01:19 AM   #13 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
P
not trying to be funny ya' fuckhead. if you took 4.30 gears and put them on a 4.10 down carrier already, what is the fucking point of this thread???? oh, that's right, there isn't one
you clearly claim that the 4.30 gears you have fit on a 4.10 down carrier, yes? so why the fuck would you question what carrier to use with an aftermarket diff?
p.s. merry fuggin' ho ho dumbfuck newb
web wheeler 4 life.
Old 12-25-2011, 01:21 AM   #14 (permalink)
Member # 168108
Old 12-25-2011, 01:53 AM   #15 (permalink)
Member # 207010
Newb, Thats Funny...
Ford sells gears up to 4.30 for the D60 front and no higher. I know the odds of the 4.10 and lower carrier are high that it will work however why the hell doesn't EVERYONE sell the lower carrier as a 4.30 and lower then... I have build enough differentials that I kow precision is key and when someone states it only fits a specific range of gears there is a reason for it. As for the current carrier in the truck I don't know shit about it.
So compatability with the current FMS Ring and pinnion, Dana Axle, and a aftermarket carrier is the point of the this thread. Sure the current open diff might measure out to be the same as the 4.10 and lower EATON but if it's off even the thickness of your tinny little pp it's not gonna work... So thanks for your input FATASS460 but it's neither required or desired...
P
Old 12-25-2011, 02:04 AM   #16 (permalink)
Havok450's Avatar
Member # 138949
Send a message via MSN to Havok450 Send a message via Yahoo to Havok450
and considering the fact that he has over 800 posts makes him a fawking noob, ive seen a couple threads he's posted in and he is rather knowlegable. Mark my words
My friend hates Chevy, but owns 2, wtf
Havok450 is offline   Reply With Quote
Old 12-25-2011, 02:20 AM   #17 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
P
all i'm gonna say is do the math fucknugget
http://www.summitracing.com/parts/MRG-904A/
can you make up the difference in shims?
web wheeler 4 life.
Old 12-25-2011, 02:25 AM   #18 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
p.s. what the fuck do "ford motorsport gears" have to do with a dana axle anyways while i'm thinking you are a douchebagel?
web wheeler 4 life.
Old 12-25-2011, 03:31 AM   #19 (permalink)
Havok450's Avatar
Member # 138949
fucknugget, now that makes me giggle
Old 12-25-2011, 03:47 AM   #20 (permalink)
Member # 207010
So fucking glad I joined this forum tonight...
P
Old 12-25-2011, 09:00 AM   #21 (permalink)
Member # 83920
P
Yeah, so are we
Be sure to have a real question when you come back.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote
Old 12-25-2011, 03:28 PM   #22 (permalink)
party wagon
FordX4-offroad's Avatar
Member # 202878
yes.
no.
maybe.
rigless
FordX4-offroad is offline   Reply With Quote
Old 12-26-2011, 02:39 PM   #23 (permalink)
Member # 198174
I've seen several of fatdans posts, he's just an asshole for some reason. I welded my front end on my 04 F-250. The weld has held up great, I broke the inner and outer axle on the driver side but not the weld. Then when you get back on the road just unlock the hubs and it's like there's nothing there. So I say weld it!!
venom8343 is offline   Reply With Quote
Old 12-26-2011, 06:22 PM   #24 (permalink)
Member # 168108
You must be running thornbirds.
Old 12-26-2011, 09:23 PM   #25 (permalink)
i win diesel!!1!
fatdan460's Avatar
Member # 158768
and i would say you are a fucknugget too
web wheeler 4 life.
