help with bellhousing - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-08-2012, 09:57 AM   #1 (permalink)
white_elephant's Avatar
Member # 99575
i got a 302 and I am hooking it up to a np435 the clutch/pressure plate and flywheel are from an 88 bronco and the tranny is from a 76 f150...when i put the tranny in place it hits the pressure plate and i cant move the engine, i took the tranny out and just put the bellhousing i can see where is hitting and is not that much can i grind the bellhousing to clear it? if not what do you think is wrong,
i found a thread about it and the guy said it was that problem but never gave out a damn solution!
by rugger:If you are going to try to destroy someone's ego then you do it without reservation.
white_elephant is offline   Reply With Quote
Old 01-08-2012, 12:28 PM   #2 (permalink)
Ditchrunner's Avatar
Member # 34517
So that clutch is from a M50D 5spd tranny? I think that might be your problem. Look for a 1984 4spd clutch/press. plate/throw out bearing.
Ditchrunner is offline   Reply With Quote
Old 01-08-2012, 08:24 PM   #3 (permalink)
Member # 99575
I will look into that, guessing those are smaller?
Old 01-10-2012, 07:06 AM   #4 (permalink)
Member # 166341
It depends on what bellhousing you have. I ran an 11 inch clutch on my 302 with an np435 but the bellhousing was from an 86. The clutch needs to match the year bellhousing and flywheel.
IIRC a 76 is a mechanical clutch fork also. You need a bellhousing that will run an external hydraulic and the fork
catfab is offline   Reply With Quote
Old 01-10-2012, 02:41 PM   #5 (permalink)
Member # 99575
Can I run a 76 clutch and press plate ? I saw someone that made the fork work with a hydraulic pump.
Old 01-10-2012, 05:08 PM   #6 (permalink)
Cactus Farmer
Dr.Danger's Avatar
Member # 168243
It's doable for sure, but I'm not sure that you'd want to run a borg & beck style clutch (3 finger). Have you compared it to an early 80's diaphragm clutch yet?
-Dave
Dr.Danger is offline   Reply With Quote
Old 01-10-2012, 08:25 PM   #7 (permalink)
Member # 99575
No really, this is scenario, this 302 is in my wrangler, the tranny is from a 76 f150 with a i6 which the bellhousing fits the 302 do everything's fits perfectly, now the pressure plate is getting stock with the bellhousing, options? I'm going to try and run an 84 pressure plate and clutch and t. Bearing.
If that doesn't work I think I might be able to grind the bellhousing to clear the pressure plate (anyone think this is a good idea?)
