EB with no lift and big tires - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-20-2002, 04:27 PM   #1 (permalink)
Member # 6708
I've been kicking around the idea of not lifting my EB at all and just hacking the hell out of the front fenders and getting the biggest flares I can fit before hitting the gas filler necks in the quater-panels. I'm thinking this would be the best for low center-of-gravity and still try and get the biggest tires for clearence.
Anybody seen this tried to the extent of fitting 35" M/T's?
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote
Old 12-20-2002, 05:22 PM   #2 (permalink)
broncobsession's Avatar
Member # 14134
Do it. Add Gorilla flares. I've seen 33's on an unlifted, so I bet you could do it. Post pics.
"I also might point out that if you only use the shock and dont buy the coil, coil overs are alot cheaper." NICK
"Also, it is my contention, that a monkey, pounding on a keyboard, would by accident and random chance, spell correctly more words than you do." - Wolf359
broncobsession is offline   Reply With Quote
Old 12-20-2002, 09:06 PM   #3 (permalink)
Member # 6708
I checked out the Gorilla Flares. I assume they are the largest flares availible. Looks about what I'm going to try. Just wondering if anybody else as seen tires that large done on an EB with no lift.
Eric
Old 12-20-2002, 09:34 PM   #4 (permalink)
Member # 13627
Send a message via AIM to 1248bullitt
I have seen a picture on this board of an eb with 44's and another eb with 38x11" boggers.
1248bullitt is offline   Reply With Quote
Old 12-20-2002, 11:56 PM   #5 (permalink)
Member # 6848
Why even run flares?
Also, you're going to have to sacrifice uptravel for center of gravity. I'd do a couple of inches just to get some extra movement.
-Jack
71 1-ton EB
BITD 7200
IronBenderII is offline   Reply With Quote
Old 12-21-2002, 01:13 AM   #6 (permalink)
Member # 13898
Send a message via AIM to HNRYS69
I have a 3.5in lift with 37s...
- Andy Henry
69 bronco, built 302, C4, BC-3.5in lift, sawzall body lift, 37" MTR's, PTO winch
[url=http://hnrys69.classicbroncos.com/]Click to visit my webpage!![/url]
HNRYS69 is offline   Reply With Quote
Old 12-21-2002, 09:40 AM   #7 (permalink)
Member # 6708
-Jack
I'd run the flares to keep the cops from hassleing me about covering the tires. And I like the look of the finished wheel opening too.
Agreed, I would be sacrificing up travel. I think I'll try it first with no lift and then go 3.5" if it is unsatisfactory for the trail runns I like to do.
HNRYS69: Got pics???
Eric
Old 12-22-2002, 11:41 AM   #8 (permalink)
Member # 5282
Send a message via AIM to RLbronco
ive got a set of warflares on mine with no lift. i put the flares up to the body line and stretched them a little. got them to go from right below the rear taillight to about 4 inches from the door, and the fronts go a little into the grille piece past the seam to about 4 inches from the door. they are HUGE. in the rear a got rid of the filler neck and moved it inside the cab and trimmed all the the edges from the inner tub that hangs in the wheel well and was running 35s for about a year. after they went bald i put my old 33s back on. the 33s look really small in the huge hole. but the 35s with 30 year old stock suspension didnt rub anywhere except the radius arms. looked like an old stomper truck toy. it was pretty cool
RLbronco is offline   Reply With Quote
Old 12-22-2002, 01:45 PM   #9 (permalink)
Member # 10433
I have 2.5 inches in suspension via James Duff kit , also 1.25 in body . I am fitting 38 x12.50 x15 on an 8inch wheel . Just a whole lot of cutting . Sorry no pics
74eb,38"tsl's, lockrite(f), spool(r)
warn alloys(f),moser 31's(r), full cage
8274, 4.5" total lift + sawzalled for
clearance
dumplin is offline   Reply With Quote
Old 12-23-2002, 05:19 AM   #10 (permalink)
Member # 6708
Thanks for the replies guys
All in all it sounds very do-able.
Eric
Old 12-23-2002, 10:47 AM   #11 (permalink)
nada
Member # 7975
38.5" x 14.50" SX's on 10" wheel with 3" body lift and 1.5" springs...
Now I have 3.5" BC coils... HOLY SHIT...those things are FUCKING TALL... already thinking on fitting 42's...
I'm Doug K... I don't need a signature.
Doug K is offline   Reply With Quote
Old 12-23-2002, 11:10 AM   #12 (permalink)
Member # 14134
Got any pics?
Old 12-23-2002, 02:37 PM   #13 (permalink)
nada
Member # 7975
no pics of the 3.5" lift coils yet... but I have these older pics of the 1.5" coils...
http://www.offroadrepublic.com/galle...lbum07/aac.jpg
It's WAY front high right now...I'll have to lift the rear about 3 inches to make it sit level.
Doug
